2002 rc, runs rough, black exhaust, won't idle - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 7 (permalink) Old 06-27-2011, 11:06 AM Thread Starter
any clue what might be going on with my rc? i only have 1400 miles on it.
awakuni is offline
post #2 of 7 (permalink) Old 06-28-2011, 05:31 AM
rvtjonny's Avatar
did you check the plugs? is there a power commander installed?
rvtjonny is offline
post #3 of 7 (permalink) Old 06-28-2011, 10:55 AM Thread Starter
bike is completely stock, i did replce the plugs, the plugs were black, running very rich
awakuni is offline
post #4 of 7 (permalink) Old 06-28-2011, 11:35 AM
Is your MAP sensor on top of your air box connected?
post #5 of 7 (permalink) Old 08-22-2011, 10:17 AM
Had this problem. Very Frustrating. After spending the time in my garage giving my new purchase a complete tune-up to include PAIR mod flapper MOD complete coolant flush and replace with engine ice and new plugs.... it still had the same issue!!! So I dug into the fuel system and found the fuel pressure regulator to be bad.
PSmithAZ is offline
post #6 of 7 (permalink) Old 08-22-2011, 10:22 AM
Wow, the failing fuel pressure regulator sure pops up a lot.
Just did mine.
Awakuni, you can lift the tank, and pull the small vacuum hose, to see if it's leaking. kind of an easy check.
post #7 of 7 (permalink) Old 08-22-2011, 04:29 PM
Quoted: 90 Post(s)
FYI The MAP sensor is on the throttle body.
The Inlet Air Temp (IAT) sensor is on the airbox top.
