2000 RC51 Shuts-off?? - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 7 (permalink) Old 07-22-2011, 04:39 PM Thread Starter
Exclamation 2000 RC51 Shuts-off??
Hello All,
I am new here so bare with me...this season is the first time that I am experiencing a problem with my bike. Basically, when I am gearing down to a stop - right at the end - when I pull in the clutch lever and blip the throttle (in 1st gear), the bike shuts down. I hear the starter noise (similar to when you use the emergency shut-off switch) and all the cluster indications/lights go off, except for my oil light. The ignition switch is obviously in the ON position, but the bike is life-less...I can start the bike again, and it does not happen all the time. If anyone has experienced this before, or can help, please let me know. I have a PCIII USB power commander, full exhaust Hindle pipes and steering dampner - all else is stock.
Thanks in advance for your time.
Maximilian
L8APEX is offline
post #2 of 7 (permalink) Old 07-22-2011, 04:42 PM
vfrsam's Avatar
sounds like an electrical issue. Check connections for moisture. have you gottin it wet lately?
vfrsam is offline
post #3 of 7 (permalink) Old 07-22-2011, 07:44 PM
Quoted: 38 Post(s)
check your ignition coils. i had the same issue. It would only happen when downshifting past neutral into first gear. if you determine that is the issue for sure i have 2 brand new ignition coils for sale. Check all your wiring for loose connections and corrosion.
gts455 is offline
post #4 of 7 (permalink) Old 07-24-2011, 01:15 AM
Is it the dreaded kick stand wiring killing the bike?
post #5 of 7 (permalink) Old 07-24-2011, 11:18 AM Thread Starter
Hey All,
Thanks for the insight. I have the bike on the stand and I will start to check all the connections, from the ignition to the kick-stand. As for the ignition coils, if they were an issue - would they not be a work/don't work type scenario? While looking around i also noticed that my right front fork seal is slightly leaking. And...at 54000km i am most likely in need of a valve adjustment.
So, to fix these issues, i will be missing some substantial riding days here in Canada...and we only get so many...lol
Thanks Again,
Maximilian
L8APEX is offline
post #6 of 7 (permalink) Old 07-24-2011, 01:35 PM
Quoted: 38 Post(s)
You would think so but its not necessarily the case. Mine used to do the same thing, downshifting approaching a turn and as soon as i'd pass neutral the bike was off. replaced the coils and it was good to go. Also check your ICU.
gts455 is offline
post #7 of 7 (permalink) Old 07-25-2011, 05:59 PM Thread Starter
Ok, sounds good...this weekend, I will be checking the IC, kick stand wiring and all connections.
Thanks again for the input.
L8APEX is offline
