coolant drain plug? - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 5 (permalink) Old 08-15-2011, 06:02 PM Thread Starter
coolant drain plug?
Is there a drain plug somewhere on the engine block to drain all the coolant out? Got the rads emptied, but I couldn't find anything about a plug in the service manual. At least not in the section 3 that I'm using right now...
Thanks.
edit: I mean section 6, cooling system.
post #2 of 5 (permalink) Old 08-15-2011, 10:02 PM
I know of no block drain for coolant.
The typical way to drain coolant is to pull the bypass hose from the water pump.
There will still be some residual coolant in the engine, so to ensure you have complete removal, you'll have to fill with distilled water, run the engine to open the thermostat to circulate coolant, then wait until the engine cools to safely drain, and possibly repeat.
post #3 of 5 (permalink) Old 08-16-2011, 01:38 AM Thread Starter
That's exactly what I did. I ran it to 200 degrees to make sure the thermostat was full open and circulating. Cool down, drain, then removed rads again to rinse and drain by hand with a couple gallons more water.
I want to look at my spark plugs that were new before riding 36 last weekend.
And glue the foam back on the rads. And... I'll think of more to check before buttoning it all back up.
Oh, the Water Pump-mechinical seal inspection hose? I think that's what it's called. Is that supposed to be a dark grey? I guess I thought it would be clear so you could see in it?
post #4 of 5 (permalink) Old 08-16-2011, 11:11 AM
The water pump inspection hose is just a hose. It can be anything if it was replaced previously. Mine is OEM, and is black rubber.
It's not what the hose looks like, it's what come out of the hose that matters.
What's important is that nothing should come out of the hose. Any fluid (water/oil) indicates a problem in the make.
post #5 of 5 (permalink) Old 08-16-2011, 11:11 PM Thread Starter
Makes sense. That's what I figgered hose tip is clean, and dry, no signs at all on the fairings either.
