Whats your dyno numbers? - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 38 (permalink) Old 08-20-2011, 11:25 PM Thread Starter
Tommysixgun's Avatar
I had the bike dyno tuned today by hordpower!! I took a nice two hour ride though ohio country and meet up with J. D. Hord. He has a really nice shop set up out their. I have a sp-1 I bought with stock exhaust, so I had to change that I found some guy on ebay selling scorpion cans and some random mid pipes for the bike I bought them and they fit. I then picked up a power commander and loaded some map off of the RC rogue site for Sato low mounts, it seemed to run alright but I figuered I'd better get it tuned right. So I had Mr Hord do it He took his time and went though the whole map and said the old map was to rich on the low end. I ended up with a max of a 122 Hp at the wheel what do you guys think is that a good number? yea I don't have any torque numbers cause aparently his shop got hit by lightning and it has played havic on his computers thats what he told me. Oh and I have not done the soft rev mod to the bike yet so I don't know mabe my HP problaly would have been higher if I had the soft rev mod.
ID:	1798   Click image for larger version
Tommysixgun is offline
post #2 of 38 (permalink) Old 08-21-2011, 03:38 AM
It seems obvious that the soft rev wasn't done, you can continue the line from where it breaks off at 9200 all the way to 10250 for the real peak.
It is not too hard to do but unless you are using that extra 5-6hp it is not necessary.
You will be amazed how much those numbers would drop if you had a tired chain and sprockets.
Tell us if you had measured fuel mileage before how beneficial was the mapping and whether it was done at all the throttle openings. There is also an accelerator pump program/feature that you can add to your map that will spice up your throttle response (free download from DJ) but may cost you a bit at the pump. It only kicks in when you yank the throttle.
ZeroGara is offline
post #3 of 38 (permalink) Old 08-21-2011, 11:37 AM Thread Starter
yea I guess all look into doing the soft rev mod, wouldn't hurt. I thought it kicked in at 9500 so I figured I wouldn't really miss 500RPM
post #4 of 38 (permalink) Old 08-21-2011, 05:46 PM
9200 is the soft limit while 10200 is the hard limit.
However 122 HP is a very respectable number.
I see that the air/fuel ratio hovers around the 13:1 ratio across the rev range, which is good.
13.2:1 is the optimal power ratio.
SubSailor is online now
post #5 of 38 (permalink) Old 08-21-2011, 08:23 PM
Smart move on the dyno tune....how much did it set you back??
post #6 of 38 (permalink) Old 08-21-2011, 10:41 PM Thread Starter
his rate is $100 an hour and thats what he charged me, an hour.
post #7 of 38 (permalink) Old 08-21-2011, 10:42 PM Thread Starter
I'm going to do the soft rev mod I just have to find a pin that fits the PCM I might have one at work
post #8 of 38 (permalink) Old 08-22-2011, 01:50 AM
sdimex's Avatar
my bike is a 2004
bike stock 118hp 68lbtq
bike not tuned with k&n air filters n yoshi cans was 122hp 70lbtq
bike tuned was 130hp 77lbtq
after soft rev mod n flapper delete 135hp 80lbtq
bike was tuned by powerhouse
2004 nicky hayden RC51
to many mods to list
sdimex is offline
post #9 of 38 (permalink) Old 09-01-2011, 11:12 AM
stock 03 with only sato banzai's dynod 123.8hp untuned. dont have any numbers on torque as they didnt hook it up to the coil wire. they were doing only HP
that was with the soft/pair/flapper intact and no power commander
ill have to dig up the dyno sheet.
just added a pc3r and plan on doing the soft/pair/flapper, snorkel and airbox over the winter and then get it tuned.... stay tuned
white91formula is offline
post #10 of 38 (permalink) Old 09-26-2011, 07:59 PM
rc51anthony's Avatar
mine will be going under the dyno soon , i have everything done now , its ready , i have a great mapping already , cant wait to see the numbers . i have had both my zx10r's done , and its a big difference the word is linear smooth to red line ,
  • Moriwaki rearsets
  • Power Commander USB
  • DID 520 gold chain
  • CRG folding clutch lever
  • Flapper PAIR EVAP removed
  • Soft Rev limiter removed
  • 15/41 gears 520
  • Vortex clip-ons
rc51anthony is offline
