Slow starting stumble - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 22 (permalink) Old 08-28-2011, 03:41 AM Thread Starter
nochain's Avatar
Curious my new bike runs great but was wondering what makes a bike bang boom start fast with the first press of the starter switch as opposed to a slower weaker start? I know a fully charged battery can make a big difference and in fact i bought one but the starting on my bike is not a bang but more of a weaker start. Its got 8K on the clock and a new battery as mentioned. I have never used the choke (will try that tomorrow to see if that helps). It has Sato low mounts and a PCIII with what I presume is the correct map (how to verify?).
Since I only have had this bike for just over a week I would like to get your inputs here on how you start the bike (Choke etc) and if it bangs to a start or are they all a little slow??? My idle is 1300 or so when warm. I live in AX and its been HOT here (the reason I have not even bothered with using a choke).
I LOVE this bike!!!!
nochain is offline
post #2 of 22 (permalink) Old 08-28-2011, 07:29 AM
vfrsam's Avatar
Mine needs the choke all the time
vfrsam is offline
post #3 of 22 (permalink) Old 08-28-2011, 10:27 AM
Weather under 80 degrees, I need the choke, just for about 15 seconds or so before the idle gets to high, I usually need to ease it in over the next 15 to 30 seconds.
If I forget to choke; it starts, then just to low of idle and it dies right away. So I pull out the choke and turn the ignition, then bam, I get that snap start you mention. Sounds pretty impressive. But I never get that on the first start. Choke or not.
It always misses the first fire stroke and catches the second one to start. It is consistant about that.
post #4 of 22 (permalink) Old 08-28-2011, 12:06 PM
I stop using the chock after I replaced the battery, fuel filter and fuel pressure regulator. It fires everytime on the first time a single burp of the throttle and it idles fine and smooth until I'm ready to ride
kpowe1 is offline
post #5 of 22 (permalink) Old 08-28-2011, 05:53 PM Thread Starter
nochain's Avatar
I just tried it with the choke first on a cold start Bam....it fired up. Looks like that's the procedure for a "cold" engine no matter what the ambient temp is at.
Kpowe what made you replace the fuel regulator? What symptoms did you have prior (i.e. was it all starting related??)?
nochain is offline
post #6 of 22 (permalink) Old 08-28-2011, 09:54 PM
Quoted: 40 Post(s)
The RC51 has no choke.....that is actually a fast idle knob.
Its best to always pull the fast idle knob out when starting no matter what the temperature.
When i start my RC51 i always have it pulled all the way out, as soon as it starts i push it right back in and let the bike get up to temp before riding.
gts455 is online now
post #7 of 22 (permalink) Old 08-29-2011, 02:02 AM Thread Starter
nochain's Avatar
GTS that's interesting I thought it was a choke. So it does not enrich the mix but increases throttle position?
nochain is offline
post #8 of 22 (permalink) Old 08-29-2011, 02:50 PM
Quoted: 40 Post(s)
Yep, it just bumps up the revs for starts....its just like holding the throttle slightly open, just its hands free.
It was put there by Honda specifically for starting the bike.
post #9 of 22 (permalink) Old 08-29-2011, 05:00 PM
When cold I, pull out the fast idle and then gradually push it in as the revs increase as it warms up.
By the time the engine almost at operating temp, the fast idle is all the way in.
post #10 of 22 (permalink) Old 08-29-2011, 11:39 PM
Technically it is a choke. Honda calls it that.
Section 3-5
CHOKE OPERATION
This model uses a bypass air volume control choke system controlled by the starter valve.
The starter valve opens the bypass air circuit via a cable when the choke knob on the left side of the frame is pulled out.
I have no idea what that means
