HELP I get roughly 70miles ona full tank! wtf. - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 17 (permalink) Old 10-01-2011, 09:15 PM Thread Starter
hi I just bought an 04 Nicky Hayden with 3k miles. I get 70miles in an tank. I dont think its normal duh.
Previous owner didnt ride it much and before he took it out he was messing around with custom maps. current mods: full 2-1 Erion exhaust, PC3, DID chain i dont know the sprocket sizes.
Will it damage the engine if I keep running it in this set up? how much will it cost to have it tuned properly? thank you for your inuts.
04RC is offline
post #2 of 17 (permalink) Old 10-01-2011, 09:19 PM
What does the oil look and smell like?
post #3 of 17 (permalink) Old 10-01-2011, 09:33 PM Thread Starter
fresh changed it les than 50 miles ago
04RC is offline
post #4 of 17 (permalink) Old 10-01-2011, 11:30 PM
If that is the case, it has to be going somewhere....Might want to go to the Dynojet website and download a base line map. I do believe there is a DJ map for the Erion pipe too.
Compression check may be in order just as a precaution.
post #5 of 17 (permalink) Old 10-02-2011, 12:26 AM
cbrbear's Avatar
how about you turn off the choke! If it is off check to make sure its not stuck open inside the TB's!
cbrbear is offline
post #6 of 17 (permalink) Old 10-02-2011, 01:59 AM
RC DAN's Avatar
I had the same thing happen to me , i changed the spark plugs and air filters and i now get to 115 to 120 miles before the gas light comes on now !!!Good luck with it !!!
RC DAN is offline
post #7 of 17 (permalink) Old 10-02-2011, 07:48 AM Thread Starter
@madbuyer Thanks man. @cbrbear How do I know if the choke it's off or not? Rpms seem fine(1200ish) @rcdan I might have to do that, but the bike has only 3k miles?
Thanks everyone. I'll keep this post up to date.
04RC is offline
post #8 of 17 (permalink) Old 10-02-2011, 08:37 AM
left side (kick stand side) there is a button tucked in the fairing just below your leg. This needs to be pushed in. Then set your idle. (Good call cbrbear)
Thats a quick and dirty check....
There are quite a few members on here from VA that are close if you require some personal service.
post #9 of 17 (permalink) Old 10-02-2011, 09:40 AM Thread Starter
Ok I'll check it. Thanks again.
04RC is offline
post #10 of 17 (permalink) Old 10-02-2011, 10:42 AM
Defender's Avatar
Those plugs have to be black by now. Time for some new ones.
Defender is offline
