Rc failure :( - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 20 (permalink) Old 12-13-2011, 05:12 PM Thread Starter
Rc failure :(
Hey fellas, i need some sound educated advise. I have an 01 RC, and it has aquired a big issue. the bike has a pwr cmndr, so just incase this is relative to this issue, i figured id mention. For a while, the bike was idling a little higher, primarily in colder weather, but now when i come to a stop, its almost like its loading with fuel and then dying. I have noticed the gas milage dropoff, and the bike smells like its running richer. whether or not the power commander is set right, i dont know. im assumming it was because the bike was tuned for the pipes- however, the batt has just been replaced. will the pwr cmndr reset? does this sound like a leaky injector? bad pressure reg maybe? In need of some serious help quik as i do not have time to run it to honda, and can tech it at my shop myself. Thanks to any advice
Jeff
RCMRS is offline
post #2 of 20 (permalink) Old 12-13-2011, 06:34 PM
jondog....insert pressure regulator picture here.....
post #3 of 20 (permalink) Old 12-13-2011, 06:39 PM Thread Starter
ill need to pull it out of the bike. tips on the best method of removal? location of regulator? i havent pulled the bike apart yet with the exception of the tank
RCMRS is offline
post #4 of 20 (permalink) Old 12-13-2011, 06:41 PM Thread Starter
and what does jondog mean? just curious
RCMRS is offline
post #5 of 20 (permalink) Old 12-13-2011, 06:42 PM Thread Starter
nvm.. got it
RCMRS is offline
post #6 of 20 (permalink) Old 12-13-2011, 07:05 PM
Originally Posted by RCMRS View Post
nvm.. got it
Have something handy to plug the fuel return hose, just in case.
post #7 of 20 (permalink) Old 12-13-2011, 07:12 PM Thread Starter
Sure, I'll try to get it out tonight. Does plugging the return improve issues that may be caused by the reg?
RCMRS is offline
post #8 of 20 (permalink) Old 12-14-2011, 10:51 AM
Your Fuel Pressure Regulator is probably the culprit. You guessed it. The symptoms you described is exactly what they will do.
Lift the tank, and the FPR is right there at the rear under it. Pull the small vacuum line, then turn on the key to let the fuel pump prime. You'll probably see the FPR drip or leak from that small nipple. If so, you need a new FPR. Here in CA they run about $50 at the dealer.
It's a real common thing with these FI Hondas.
btw, I still haven't figured out what a jondog is either
post #9 of 20 (permalink) Old 12-14-2011, 12:21 PM
No, but it may prevent spilling fuel all over the place if the tank is full.
The fuel pump pressurizes the fuel line to 50 PSI over manifold pressure.
The fuel pressure regulator alters the fuel pressure due to altitude or ram air effect changes to maintain 50 PSI over manifold pressure.
The return path for the fuel pressure regulator back to the tank is via the fuel return hose.
post #10 of 20 (permalink) Old 12-14-2011, 08:29 PM Thread Starter
Ok, pulled the return line off, and fuel is raining from the nipple even without priming the system. Is this normal? It keeps draining with tank off bike too... Ideas?
RCMRS is offline
