no compression rear cylinger with kent cams - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 53 (permalink) Old 03-26-2015, 06:38 PM Thread Starter
ogiehooker's Avatar
Quoted: 29 Post(s)
Hey guys...shop says my bike has normal compression with stock cams but 150-160 front and 35 rear with roger ditchfields kent cams, degreed to his specs.
ANY ideas? No valve leaks, rings in ok...I 'm at a loss.
Derrel
ogiehooker is offline
post #2 of 53 (permalink) Old 03-26-2015, 07:32 PM
Quoted: 135 Post(s)
Make sure they have the cams synced correctly after swapping them......it been known a time or two for cams to be 180* out of spec when installed.....just for starters
sbkdrew is offline
post #3 of 53 (permalink) Old 03-26-2015, 07:36 PM Thread Starter
ogiehooker's Avatar
Quoted: 29 Post(s)
Hard to believe a race team shop can't figure it out...they're degreed to Roger's specs they say.....if they can install stock cams correctly, hard to believe they can't do the same with KC's....especially f to r discrepancy...160 front sounds phat!
Tks bud!
post #4 of 53 (permalink) Old 03-26-2015, 09:35 PM
Quoted: 135 Post(s)
well, like the saying says, happens to the best of us sometimes....I'm just throwing ideas in the hat.....never know
sbkdrew is offline
post #5 of 53 (permalink) Old 03-27-2015, 03:16 AM
Quoted: 82 Post(s)
If it is fine with stock cams it can only be one of 3 things
They have not adjusted the valve clearance to suit the kent cams
They are timed incorrectly
they installed the cams incorrectly
http://www.kentcams.com/product-deta...ft/HON21-Race/
dansp1 is offline
post #6 of 53 (permalink) Old 03-27-2015, 08:00 AM
wingnutt's Avatar
Quoted: 58 Post(s)
I always listen to certain people with RC-51 expertise........
wingnutt is offline
post #7 of 53 (permalink) Old 03-27-2015, 10:05 AM
I wonder the valves have been damaged from incorrect cam timing? If they put back standard cam on the back cyl, does it then give a high reading of compression?
post #8 of 53 (permalink) Old 03-27-2015, 10:44 AM
wingnutt's Avatar
Quoted: 58 Post(s)
I do-not believe these are interference engines.
wingnutt is offline
post #9 of 53 (permalink) Old 03-27-2015, 11:54 AM
Not the way I understand. In fact most all motorcycle engines are interference design, especially sport bikes.
post #10 of 53 (permalink) Old 03-27-2015, 12:06 PM
wingnutt's Avatar
Quoted: 58 Post(s)
There are two reasons I think that.
I saw an RC engine that was 180 out and cranked over then corrected with no damage.
Unlike most sportbikes our have very low c/r's
wingnutt is offline
