cant shift into first - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 21 (permalink) Old 02-13-2012, 05:55 PM Thread Starter
so all of a sudden i come to a light and i cant shift into first gear! this happened in one day. i had trouble a couple times today but only today that it was tough but i still got it there. now not at all. it just wont get past N. all other gears are fine. even with the bike not running i couldnt do it by hand either. my clutch feels tight and normal but i know the clutch fluid is dark and could use a change. is that all there is to it? thanks!
2003 RC51 #152 of 2000
The Man Who Sleeps With His Bike
WarpSpeed is offline
post #2 of 21 (permalink) Old 02-13-2012, 06:25 PM
What does the shift lever feel like when you try to shift to 1st?
Does it actually depress or does it not move?
And does it do this even if the bike is rocked back and forth to rotate the gears?
post #3 of 21 (permalink) Old 02-13-2012, 06:28 PM Thread Starter
it does not move. before it stopped altogether it would make a grinding sound and it felt awful. rocking does nothing
post #4 of 21 (permalink) Old 02-13-2012, 07:47 PM
If you can't get it in with the engine stopped, moving the bike back & fourth then you might have a gearbox problem. Has the bike been used for power wheelies, or anything like that?
post #5 of 21 (permalink) Old 02-13-2012, 07:55 PM Thread Starter
I've only had the bike 2 months and the prev. Owner didn't mention stunting of course
post #6 of 21 (permalink) Old 02-13-2012, 08:59 PM
Did you have the bike jump out of 1st occasionally while riding?
If so, then it is more likely a bent fork.
post #7 of 21 (permalink) Old 02-13-2012, 09:42 PM Thread Starter
no that has never happened
post #8 of 21 (permalink) Old 02-14-2012, 12:27 PM
I figure it's either a bent fork, some problem with the shift mechanism or linkage, or some obstruction on the drum preventing movement of the fork along the groove.
It's not that complicated of a mechanical system.
post #9 of 21 (permalink) Old 02-14-2012, 07:09 PM
Could it be the return spring??
Name:	Return Spring.jpg
post #10 of 21 (permalink) Old 02-14-2012, 09:40 PM
In post #3 he mentioned that the shifter won't even move towards 1st gear, yet all other gears work fine.
Also it's reported that it didn't jump out of 1st when it was working for a while.
It almost sounds like a form of obstruction preventing the drum from rotating towards 1st engagement.
I guess it could be the return spring, but engagement of the other gears works fine reportedly.
In the end, it's just going to require some inspection to isolate the problem.
It will be interesting on what the fault is.
