Clutch issues - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 11 (permalink) Old 09-06-2015, 05:02 AM Thread Starter
Location: From Vancouver/Canada lives in Geneva/Switzerland
Quoted: 18 Post(s)
Clutch issues
Hi All,
When changing my front sprocket i messed up my clutch slave. I have bled the clutch once and there was a lot of air. Here is what it looks like any suggestions on how to push the piston back. Do i need to drain the system and then refill?
Thanks V
ID:	93162   Click image for larger version
ID:	93170   Click image for larger version
Vnaik is offline
post #2 of 11 (permalink) Old 09-06-2015, 10:27 AM
Quoted: 85 Post(s)
The piston is at an angle, you need to straighten it and push it back in then bleed the system
dansp1 is online now
post #3 of 11 (permalink) Old 09-06-2015, 10:38 AM Thread Starter
Quoted: 18 Post(s)
I tried pushing it back but its pretty solid. how do you straighten it? Thanks for your help.
Vnaik is offline
post #4 of 11 (permalink) Old 09-06-2015, 10:43 AM
Quoted: 85 Post(s)
You can pump it out or maybe use a pipe that fits inside the piston and gently rock it straight
post #5 of 11 (permalink) Old 09-06-2015, 10:45 AM
Quoted: 85 Post(s)
It's the second pic that shows it at an angle, is that how it is now?
post #6 of 11 (permalink) Old 09-06-2015, 11:34 AM Thread Starter
Quoted: 18 Post(s)
Yes thats how it is now. will try to use the pipe technique. Is this normal?
Vnaik is offline
post #7 of 11 (permalink) Old 09-06-2015, 12:56 PM
Quoted: 85 Post(s)
No, it has come out too far when your friend piled the lever while it was disassembled, when you tried to put it back on the piston skewed to one side
post #8 of 11 (permalink) Old 09-22-2015, 05:39 AM Thread Starter
Quoted: 18 Post(s)
Ok so tried to work on this the other day no luck. Have ordered the replacement Spring, Pistone seal and Oil seal. Do i drain the clutch fluid and then get it out? What do you mean pump it out? Its pretty solid where it is. Any advice is appriciated....
Vnaik is offline
post #9 of 11 (permalink) Old 09-22-2015, 11:35 AM
At Your Own Risk!
I might try using a deadblow or plastic hammer to gently hammer the piston straight. Then I'd try to remove it.
You risk damaging the oring seal between the caliper and the piston, so be careful.
post #10 of 11 (permalink) Old 09-22-2015, 12:07 PM
CapeCodderRC's Avatar
Quoted: 114 Post(s)
probably cheaper and less trouble to just get another one.... quicker too
Clint / 2000 RC51 #414
CapeCodderRC is offline
