Intermitten electrical issues - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 11 (permalink) Old 04-23-2012, 03:48 AM Thread Starter
Hey guys, just wondering if any one had ever experienced intermittent electrical problems on their Rc? About 3 weeks ago I was riding to the gas station and the bike started to shutter I eventually ran out of gas on the corner of te station (lucky me). So I fill up and think it was probably the gas that made the bike shutter, no such luck I ride fairly spirted to idk get it flowing again and I get a few miles down the road and my Rc just dies. Pushed started it with help of a passerby and got down a block but every time I pulled in the clutch to to stop and it would idle it would try and turn off. I took out my battery and brought it too auto zone they tested it and the meter read bad so I got one from there and my bike again had life. It was working fine I checked the connection on the rectifier and looked for a wire grounding out or something the pcIII harness feels old and brittle as rubber does sometimes. The other day I was riding home after having her sit for a few days and she's acting up again I made it too a parking lot close to my work and died again. I took out the battery and autozones meter said it was good I thought maybe it was the fuel filter being dirty that would cause this problem so I got some sea foam and poured it in and ran it for about 10 minutes and rossetti it around to see if it had temporarily fixed the problem but low and behold it hadn't... Now the bike won't start and I'm throwing a FI code 18. I says cam pulse generator but I think it may be a loose sensor or maybe my pcIII or maybe I put too much sea foam in? Anyways any help or suggestions would be greatly appreciated
Torque is offline
post #2 of 11 (permalink) Old 04-23-2012, 06:45 AM
COBRA90GT's Avatar
Quoted: 47 Post(s)
Well, how much SeaFoam did you pour in? Did you read the directions on the can and pour in the corresponding amount?
'06 Black/Metallic Gray RC51
-Competition Werkes FE w/
Clear Alternatives IT
'02 Silver/Black CBR 954RR
COBRA90GT is offline
post #3 of 11 (permalink) Old 04-23-2012, 08:15 AM Thread Starter
I didn't read the instructions as I use this product fairly often. I put in maybe a quarter of a bottle...
Torque is offline
post #4 of 11 (permalink) Old 04-23-2012, 03:55 PM
I have two things that have happened to me, giving me the symptoms you described.
Do you have a PCIIIr? If so, your code 18 could very well be your small harness grounding out somewhere. As I recall, there's 2 or 3 wires that run from the PC's main harness, to the small red connectors tucked just under and behind the left-side radiator. You can access them from the front of your bike, just behind the front lower/inner cowl. It's a big rubber bell with several other small connectors-look for the red ones. Those are your pulse gen connectors. You can totally bypass the PC's connectors, and just plug the bikes two red connectors back together like they would be from the factory. It wont have any effect on your PC's performance, unless you have special fuel mapping for each individual cylinder.
My other thought is your fuel pressure regulator. Did you check that for leakage. But I don't think that would throw any codes, so not my first guess.
post #5 of 11 (permalink) Old 04-23-2012, 04:17 PM Thread Starter
Thanks for the input jondog9 I'm at work right now but will check when I can. I bought the bike with the power commander so I'm not sure exactly witch it is. Again thanks for the input I'll post what I find
Torque is offline
post #6 of 11 (permalink) Old 04-23-2012, 04:18 PM Thread Starter
Also how would I Check the fuel pressure regulator?
Torque is offline
post #7 of 11 (permalink) Old 04-23-2012, 04:28 PM
post #8 of 11 (permalink) Old 04-23-2012, 04:35 PM Thread Starter
Oh sweet yeah I will definately check that thanks again!
Torque is offline
post #9 of 11 (permalink) Old 04-23-2012, 04:47 PM
Glad to help, hope I got you on the right track.
post #10 of 11 (permalink) Old 04-24-2012, 03:08 AM Thread Starter
UPDATE
Thanks again everyone I checked the FPR and it was good I checked those damn red connections that took me the better part of an hour with these damn man hands I mine but in the end it was some damn wires shorting out on the sensor in the very back right mines an 02 so I looked it up and it's not the fuel cut off relay still don't know what it is but I know that she rides again!!!
Thanks again if anyone knows what it is let me know please
Torque is offline
