cam cover gasket blown out - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 12 (permalink) Old 05-24-2012, 04:41 PM Thread Starter
Hi today in really warm weather and with the bike being in the sun for a few hours I decided to go for a ride but as I started the engine after a quick break there was a big bang and a puff of smoke it turns out the two disc shaped parts of the cam cover gasket had blown out. What can cause this could it be a blocked breather or a overheating problem as my fan works when it wants (New thermostat on order) cheers
Deano is offline
post #2 of 12 (permalink) Old 05-24-2012, 06:50 PM
An internal combustion engine is just a big air pump, it needs to vent excess pressure via the crankcase vent/venting...I'm gonna hazard a guess and say the crankcase breather is not doing its job.
I've have lots of time in motors just not the RC haven't any reason to so I don't know exact location of crankcase vent but I'm sure some that does will chime in. My guess somewhere between the Vee's of the motor.
post #3 of 12 (permalink) Old 05-24-2012, 09:19 PM
The crankcase vent is on the upper front valve cover.
It has a hose that routes to the crankcase vent catch bottle on the right side, near the rear cylinder (next to the thermostat).
From there, there's a hose that attaches to the airbox to vent crankcase vapors into the airbox to be burned.
And it also has a drain hose and cap for the catch bottle on the left side, that periodically needs draining (good thing to check every oil change).
post #4 of 12 (permalink) Old 05-25-2012, 01:23 AM
Quoted: 37 Post(s)
i think i have some spare gaskets if you need them.
gts455 is offline
post #5 of 12 (permalink) Old 05-25-2012, 02:43 AM
Not a common problem on the RC, but you do have to check/drain the crankcase/airbox hose every now and then
2000 VTRSP1
mondo is offline
post #6 of 12 (permalink) Old 05-26-2012, 03:54 AM Thread Starter
Just checked the breather and catch bottle everything looks ok and blows through ok I changed the airfilters just in case and I'm gunna change the map on the pc3 just in case its running too lean and overheating the oil. I am interested int the rear valve cover gasket if you've got one GTs455. It's been a hectic few months with the rc51 I got it in Feb its coils went down two weeks later then three weeks after that the old pc3 went pop then four weeks ago the lhs rad developed a crack and had to be recored and now after only the 2nd good ride it goes pop again I bet Colin Edwards or joey Dunlop never had this much trouble hahaha
Deano is offline
post #7 of 12 (permalink) Old 05-26-2012, 09:04 AM
Quoted: 37 Post(s)
sure thing. will take a look today. Had bought a new set when i did my cams, but they did not need changing.
gts455 is offline
post #8 of 12 (permalink) Old 05-28-2012, 04:35 PM Thread Starter
Hi guys quick update on the gasket front its still blowing out but it looks worn and there is evidence of a sealent where the discs are so I'm hoping its just,a weakened gasket I did check my oil and coolant and neither was contaminated so it should be a simple fix
Deano is offline
post #9 of 12 (permalink) Old 05-29-2012, 05:56 AM
Quoted: 37 Post(s)
Tried finding the gaskets with no luck, i may have already gotten rid of them or misplaced them. Really thought i had a set. Sorry guys.
gts455 is offline
post #10 of 12 (permalink) Old 05-29-2012, 10:48 AM
http://www.bikebandit.com/houseofmot...1330#sch304616
Parts break down of the valve covers............. I would check the reed valves in the valve covers. If you have to replace them replace the gaskets as well (and don't forget to replace the gaskets around the bolts as well!)
Sean
Sport is offline
