Sato mids not fitting with cans - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 10 (permalink) Old 05-25-2012, 10:04 AM Thread Starter
Badcummins59's Avatar
I have a gap about 1/4" maybe less with my sato banzai mid to cans. I can not for the life of me get them tight which leads to floppy exhaust...
Also the rubberized clamps are loose. Should I buy new rubber?
Badcummins59 is offline
post #2 of 10 (permalink) Old 05-27-2012, 06:52 AM Thread Starter
Anyone??? No one with the same issue?
post #3 of 10 (permalink) Old 05-27-2012, 05:23 PM
Post up a picture.
Are the diameters not matching up, or are the can inlets not sliding all the way onto the mids?
I'm always right.
2011 Bike of the Year
post #4 of 10 (permalink) Old 05-27-2012, 06:28 PM Thread Starter
They arent sliding all the way on
post #5 of 10 (permalink) Old 05-28-2012, 12:19 AM
Mids don't match the cans...? ...wrong mids?
badandy is offline
post #6 of 10 (permalink) Old 05-28-2012, 09:09 AM Thread Starter
here is the issue... they are sato banzai mid pipes same as my damaged ones
post #7 of 10 (permalink) Old 05-30-2012, 10:29 AM
JusAnadaMexican's Avatar
2 solutions
You can try an use a rubber mallet? also run the bike till the pipes get hot and see if it'll slide in... I meant heat up the inlet so that it expands just a bit to slide through all the way. That might be better than the mallet idea.
2001 rc51 upgraded
2006 650R Ninja sold
JusAnadaMexican is offline
post #8 of 10 (permalink) Old 05-30-2012, 11:19 AM
Measure how much room (length) you have on the inside of the inlet and compare that to how much there is on the mid after the welded on ring. They may have made a change in length, and if those aren't the original cans/mids set then that might be the issue. I think there is probably just something in there no letting them seat.
I'm always right.
post #9 of 10 (permalink) Old 05-30-2012, 12:39 PM
Quoted: 331 Post(s)
That happens all the time with Sato exhausts. They constantly made changes to their product lines with revisions that made their products better and when they did that they would retool all their product lines to the new specs unlike some companies that churn out the same flawed products for decades at a time.
The downside is you end up with a lot of different styles of cans, inlets, spring points etc and once the parts are discontinued as they have been then people start mixing & matching parts from other models to make it fit.
post #10 of 10 (permalink) Old 05-30-2012, 12:42 PM
There you go, break out the dremel and make some nice titanium sparks.
I'm always right.
