sp1 and sp2 motors - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 8 (permalink) Old 05-26-2012, 04:55 PM Thread Starter
sp1 and sp2 motors
I was just wondering what were the major differences were between the two different models? Reason I ask is because I have an sp2 and I have the opportunity to pick up a motor but its off an sp1 and if it requires a bunch of work to swap them then it might not be worth the time.
Thanks for any advise.
1988 zx750 ninja-sold
1995 cbr600f3-sold
2002 cbr954rr-sold
2002 r6-stunt bike
2002 rc51 sp2-loving life
RC51bullet is offline
post #2 of 8 (permalink) Old 05-26-2012, 11:00 PM
1971allchaos's Avatar
Quoted: 26 Post(s)
Most all of the changes were done with the chassis (forks, swingarm, etc.) and electronics...
Engines are different in the heads(intake ports, exhaust ports, exhaust header(with the D-shape)). Then being the that Honda improved the intake /enlarging the ports- which gave opportunity for the Larger 62mm throttle bodies,(the SP-1 engines has 54mm thottle bodies, and smaller intake ports)..
It would be a good investment if your bottom end(transmission, crankshaft,etc... took a dump) IMHP...
1971allchaos is offline
post #3 of 8 (permalink) Old 05-27-2012, 12:24 AM
The difference in the motors are SP2 has improved clutch, D shape exhaust ports,improved pistons, 62mm throttle bodys (only bigger throttle bodys, intake port same size) and a sleeve in the swingarm mounting point.The motors will fit either frame.The 54mm throttle bodys of the SP1 are better for the street.
2000 VTRSP1
mondo is offline
post #4 of 8 (permalink) Old 06-19-2014, 12:11 AM
PEPE's Avatar
Hi, Has anyone installed an SP2 crank in a SP1 engine?
Cheers
PEPE is offline
post #5 of 8 (permalink) Old 06-19-2014, 12:19 AM
Cheers
Only major difference is the exhaust ports on the SP2 heads.
Bottom ends are the same.
post #6 of 8 (permalink) Old 06-19-2014, 12:39 PM
Quoted: 135 Post(s)
Cheers
Just be sure to make note of the markings and stampings on the crank to get the correct combination of crank bearings. You'd have to refer to a service manual to get the right ones.
sbkdrew is offline
post #7 of 8 (permalink) Old 06-19-2014, 02:42 PM
wingnutt's Avatar
Quoted: 58 Post(s)
Andy, you probably just saved someone hours of pain.
wingnutt is offline
post #8 of 8 (permalink) Old 06-20-2014, 06:11 AM
PEPE's Avatar
Many thanks, I am well across the shell bearing issues, I am just struggling to figure out why the different part numbers…
[-D30 verses -000 ] the two engines share so many common parts. The listing in the parts manual and online [I.P.B’s] still do not show that it is an alternate.
I am rebuilding a SP1 engine that came out of the bike from new and the left hand side main is well out of tolerance and a slight uneven wear on the big end because of this I guess.
I have purchased a SP2 crank with very low mileage out of the USA to see if it will fit as I am guessing it will.
Cheers
PEPE is offline
