Cam Installation - Honda RC51 Forum : RC51 Motorcycle Forums
  • 1 Post By jondog9
post #1 of 4 (permalink) Old 02-26-2016, 10:50 AM Thread Starter
daves-cave's Avatar
Quoted: 4 Post(s)
Cam Installation
Probably covered here somewhere but I can't find a definitive answer.
When installing cams when all four have been removed;
Rotate engine to the FT mark - check
Install camshafts with index marks facing outwards - check
My question is should the piston for the cylinder (both front and rear) be at top dead centre when installing the cams?
Thanks in advance
daves-cave is offline
post #2 of 4 (permalink) Old 02-26-2016, 04:06 PM
I don't have an answer, but when I did it, the Honda service manual covered it all.
No need to double post the same thread.
The How To forum isn't for questions, it's for explaining how to do something step by step.
MakisRC51 likes this.
post #3 of 4 (permalink) Old 02-27-2016, 02:10 AM
FT is for Front cylinder TDC. Then you install the front cylinder's cams with their marks as you described.
Then you rotate the crank 270 deg. counterclockwise...... You'll find that there's a mark there for Rear cylinder TDC. Then you install the cams on the rear cylinder with their marks as you described.
Read carefully the service manual first.
Strikes me odd you didn't read it before beginning the whole process.
Good luck
post #4 of 4 (permalink) Old 02-27-2016, 06:44 AM
KoleDeRacer's Avatar
Quoted: 62 Post(s)
1+ read the manual.
They are free everywhere. I printed it off at work on the xerox and had my grad student organize it into a binder with all the tabs.
2003 RC
1988 FZR1000R
2013 YZ-450f
1974 Yamaha RD350
1971 Honda CB500
KoleDeRacer is offline
