modifying oil pan. need help - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 9 (permalink) Old 09-12-2012, 06:45 PM Thread Starter
I have a RC51 in a Quad that i do competitive hillclimbs with. It does kick ass but i want to shorten up the oil pan more. Currently i have a oil pan machined out of billet aluminum and its shortened it about 1-1/2inches. i trimmed the relief valve a little and shortened the sump tube also. After 4 years of running i m doin larger and larger jumps and the oil pan is hitting the ground more and more.
I would like to shorted it up so its only about 1 in deep or less.
My questions are;
-what can i do with the relief valve? plug it?
-Can i do something like a dry sump set up?
-how much oil should i run?
-can i over fill it even though it would have the correct amount of oil in it?
It only runs for a couple minutes at a time.
I m sure i ll get responses saying it can t be done but that philosophy does not exist in my garage
hondaman417 is offline
post #2 of 9 (permalink) Old 09-12-2012, 08:45 PM
rvtjonny's Avatar
Question skid plate
first off, you need to put some pics up of this thing so we can see it
Why not keep the current oil pan set up and run a skid plate on the bottom of the bike..
rvtjonny is offline
post #3 of 9 (permalink) Old 09-12-2012, 08:51 PM Thread Starter
i ll try to get a pic up tomorrow.
i want to shorten it so i can gain ground clearance. this thing gets jumped 10+ft in the air and the landings arent always pretty
the one on it now is made 3/8in thick on the bottom and 1/4in on the sides so i dont run a skid plate
post #4 of 9 (permalink) Old 09-12-2012, 08:52 PM Thread Starter
i do have some pics in my album but none of the oil pan
post #5 of 9 (permalink) Old 09-13-2012, 10:27 AM
TLRSKUNK's Avatar
Quoted: 5 Post(s)
BAD ASS!!!
TLRSKUNK is offline
post #6 of 9 (permalink) Old 09-13-2012, 02:37 PM
nwall1's Avatar
Damn I bet that thing is rowdy
nwall1 is offline
post #7 of 9 (permalink) Old 09-13-2012, 02:51 PM
screamin chief's Avatar
Maybe beefing up your suspension a little more is a better alternative. Doubt another inch off would make that much difference
Sent from my HTC PH39100 using Motorcycle.com Free App
2000 RC51
1985 ATC 350X
2009 Silverado SS clone
Lots and lots of guns!lol
screamin chief is offline
post #8 of 9 (permalink) Old 09-13-2012, 03:12 PM Thread Starter
this is the oil pan i have now. i want to get it to sit up in the frame some more
post #9 of 9 (permalink) Old 09-13-2012, 03:18 PM Thread Starter
As far as beefing up the suspension, theres only so much that can be done. i got the suspension tuned in pretty good. it takes alot to land a 500 lb quad softly. if i were to make it too stiff it would bounce all over the place and wouldn t put the power to the ground. if i would raise the quad up to give it more ground clearance i would be raising the center of gravity and thats no good for hillclimbing.
