rc51 sp1 sp2 engines - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 7 (permalink) Old 10-04-2012, 01:03 AM Thread Starter
Sniper's Avatar
So i blew up my engine. rod bearings, crank bearings, scored cylinders, cam guides ect all shot to hell..
I found a sp1 motor on ebay, complete kit with throttle bodies. my question is i have a sp2... will everything bolt up and go, or do i need to swap a set of sp2 heads onto the motor?
2002 Honda RVT1000 RC51
Facebook
Sniper is offline
post #2 of 7 (permalink) Old 10-04-2012, 01:11 AM
JusAnadaMexican's Avatar
should we dare ask how this happened? if you do a bit more research i think there was a couple of threads here that had similar swap projects, if not try speedzilla too.
2001 rc51 upgraded
2006 650R Ninja sold
JusAnadaMexican is offline
post #3 of 7 (permalink) Old 10-04-2012, 01:28 AM Thread Starter
Sniper's Avatar
Riding with friends when my oil light never came on. While riding the motor seized and wouldn't start. get home to take clutch cover off and see the oil pump gear sitting in the back corner of the engine... and i saw, but was wondering if all i needed to do was swap sp2 heads and im golden or if i need more than that.
Facebook
Sniper is offline
post #4 of 7 (permalink) Old 10-06-2012, 01:22 PM
Just swap over your TB's and oil lines, and you're good to go.
varium is offline
post #5 of 7 (permalink) Old 10-06-2012, 02:03 PM Thread Starter
Sniper's Avatar
thought the heads are different where i need to swap them over for the larger throttle bodies that the sp2 has..
Facebook
Sniper is offline
post #6 of 7 (permalink) Old 10-06-2012, 02:27 PM
cantonRC's Avatar
The exhaust ports are diffrent you may have a problem there. The sp1 are round and the sp2 are D shaped.
cantonRC is offline
post #7 of 7 (permalink) Old 10-06-2012, 03:04 PM
You can either sit there and think all you want or use the search feature since you don't believe what folks have told you. Its been covered ad nauseum over on zilla, and it should be covered here as well.
While exhaust ports are different they will fit each other with a little work. Again, the search feature is your friend.
Or, JUST BUY AN SP2 MOTOR AND BE DONE WITH IT.
varium is offline
