Cooling System Flush? - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 19 (permalink) Old 10-26-2012, 02:04 PM Thread Starter
Rugid's Avatar
I run deionized water with water wetter. Should I flush my system annually?
Rugid is offline
post #2 of 19 (permalink) Old 10-26-2012, 02:07 PM
No, imo. And don't let it freeze.
post #3 of 19 (permalink) Old 10-26-2012, 02:13 PM Thread Starter
Rugid's Avatar
So every 2 years according to the manual? It sits in a heated garage kwtoxman.
Rugid is offline
post #4 of 19 (permalink) Old 10-26-2012, 03:02 PM
COBRA90GT's Avatar
Quoted: 49 Post(s)
Every two years should be adequate. I wouldn't bother changing it out EVERY year unless you are racking up HUGE commuter-like mileage each season...
'06 Black/Metallic Gray RC51
-Competition Werkes FE w/
Clear Alternatives IT
'02 Silver/Black CBR 954RR
COBRA90GT is offline
post #5 of 19 (permalink) Old 10-27-2012, 07:49 PM
Are you racing it?
I'm always right.
2011 Bike of the Year
post #6 of 19 (permalink) Old 10-27-2012, 10:32 PM Thread Starter
Rugid's Avatar
Originally Posted by b.miller123 View Post
Are you racing it?
Was ( until they demolished our track ) Now I have a 3 hour drive to Stratotech up in Edmonton.
Rugid is offline
post #7 of 19 (permalink) Old 10-27-2012, 11:18 PM
Quoted: 90 Post(s)
If you drain all the coolant out of your engine and radiators, you can then fill with waterless coolant, which will last the life of the bike.
http://www.evanscooling.com/
post #8 of 19 (permalink) Old 10-28-2012, 01:15 AM
Or, until your mechanical seals give out in the water pump assy....I change mine every couple just cause I have nothing else to do
post #9 of 19 (permalink) Old 11-02-2012, 11:02 PM
Hig
Hig's Avatar
When I run out of crap to buy or am in the moment of satisfaction of the bike in its current state...I regress to unnecessary maintenance.
That being said, if you are bored and it has been minute- go for it. You can clean stuff while you are in there which will add another hour to a relatively simple process. (which is also another hour away from household 6)
Hig is offline
post #10 of 19 (permalink) Old 11-02-2012, 11:08 PM
Quoted: 90 Post(s)
In which case Evans says to drain the existing coolant into a clean container, fix/replace the water pump.
Then re-use the drained coolant and top up what's needed.
