Cylinders? - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 4 (permalink) Old 08-02-2018, 01:49 PM Thread Starter
Cylinders?
Ok been a while guys and gals. I have been doing some searching and cant find the correct answers.
I have an 03 rc51. And am going to do rings (already torn down) are the cylinders plated from factory.
I have seen mixed thoughts on giving them a hone vs bore.
Has anyone had any luck with just givibg it a hone job as I really dont want to send it out if i dont have to.
I havent ridden it in about 4 years.. I miss it lol.. It was smoking like a siv before putting it away. The cylinder walls dont look horible but still need to do a bore measurement. already planning on doing valve seals.
Thanks again
ironraptor04 is offline
post #2 of 4 (permalink) Old 08-02-2018, 03:44 PM
https://www.rc51forums.com/forums/14...html#post38318
This member has been a great resource for RC51 information on this forum.
post #3 of 4 (permalink) Old 08-05-2018, 07:49 PM
Quoted: 15 Post(s)
You will need to have the cylinders coated with nikasil.
5.4 speedster is offline
post #4 of 4 (permalink) Old 08-07-2018, 03:33 PM
JB's_SP3's Avatar
Thanks again
The cylinders are not Nikasil plated from the factory, the alloy is impregnated with a Honda proprietary compound and honing is a specialised process and (in my country at least) not cheap. They wear fast. Honda make .25 mm and .50 mm oversize pistons so over-boring is one option, however if I was in the US I'd send the block plus a pair of stock size pistons (OEM or JE 11.1:1) to Millennium Technologies and have them plated to the ideal tolerances.
JB's_SP3 is offline
