18 tooth or bigger front sprocket? - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 5 (permalink) Old 09-13-2010, 03:07 PM Thread Starter
twvette's Avatar
For my special application, I need to get a bit more top end as I topping out at 65MPH now (dont need much more) and would like to do a little less shifting for normal use. I currently have the 16 tooth Honda on the front and a special busa 17 on the rear connected to the gearbox I am using. I see there are 17 tooth fronts and it seems this is the biggest. Anyone seen 18 tooth or higher or does it just not fit beyond 17 teeth? I really do not want to go smaller in the rear.
Also I read one post about changing the front sprocket without removing the chain! How is this possible? You have to remove the cover anyways, correct?
Thanks as usual ...
Polaris RZR with an '04 SP2 transplanted in it. Chain driven through a gear box with axles and CVs. The only thing left stock on the RZR is the frame and plastics . But, the frame is beef'd up too .
twvette is offline
post #2 of 5 (permalink) Old 09-13-2010, 04:45 PM
I'm sure this question doesn't pop up often.
I have no idea what the maximum sprocket diameter will fit.
As you can see, there's not a lot of room with the 16T OEM front sprocket.
You might be able find a company to make a special 17T front, but I don't know exactly how much larger you can go before starting to hit something.
post #3 of 5 (permalink) Old 09-14-2010, 05:03 PM Thread Starter
twvette's Avatar
Yeah, thats already a tight fit looks like. I have a 17t on order and several seem to make this but was hoping to go bigger but does not not look like it. Thanks as usual ...
twvette is offline
post #4 of 5 (permalink) Old 09-14-2010, 10:01 PM
I don't see how you decrease your final ratio much more without going to jack-shaft system to be able to install a larger diameter sprocket ahead of the final drive sprocket.
post #5 of 5 (permalink) Old 10-07-2010, 10:31 AM Thread Starter
twvette's Avatar
FYI, my 17 tooth front went on ok. It might slightly be rubbing on the top of the cover near the rear but not sure yet. My chain angle is much different so I dont think it would likely rub in a normal application. I did find one place that listed a 19 tooth and I think it might actually fit too.
twvette is offline
