spal fans radiator cooling - Honda RC51 Forum : RC51 Motorcycle Forums
LinkBack Thread Tools
Old 05-05-2014, 11:40 PM Thread Starter
Ok, the title is a little nutty, I tried to make it search friendly.
With summer coming up, we always get talking about keeping our RC51's a little cooler and the topic of aftermarket SPAL fans always comes up.
BMiller - not to be confused with b.miller123 - put up a thread about his conversion here in our forum -
https://www.rc51forums.com/forums/showthread.php?t=7997
And on Speedzilla -
http://www.speedzilla.com/forums/hon...installed.html
Lot's of good information.
About doing this conversion to a SP1: I'm thinking we should use a larger fan on the left radiator - but make sure it's pushing some decent CFM's and it's within an amperage draw that's compatible. I doubt there's enough room for a fan on the right radiator, unless the oil cooler is repositioned.
This is speculation, I've thought about it, I mocked up a fan on the right radiator and that's when I discovered it simply won't fit without modification.
If anyone here has mounted spal fan(s) to a SP1, please chime in.
Old 05-05-2014, 11:53 PM
ive thought about a spal fan on my sp1 but in 90 degree weather the fan kicks on at 221 every time and takes it down to 209. i just dont really see the need. however itll soon be 100+ degrees here, but id think regard less the fan will always kick on at 221, and theoretically it should never get higher than that???
if anything i'm thinking a manual switch is something i want to do, but i thought i remember that wasnt an option with the sp1?
thaddeus is offline
Old 05-06-2014, 12:09 AM
Quoted: 37 Post(s)
Manual switch is possible, it's an easy job. i had it done on mine.
gts455 is offline
Old 05-06-2014, 12:34 AM Thread Starter
Manual switch is a snap for the SP1's. Just splice in a wire to the single wire that runs to the thermo/switch on the left radiator. Run the other end to one of the spades on the switch. Take a second wire and ground it to the frame. Run the other end to the second spade of the switch.
Done!
Your fan will still automatically kick on when you don't want to be bothered manually switching.
Old 05-06-2014, 01:00 PM
jon, do you have a pic of what kind of switch youre using and how you have it mounted?
thaddeus is offline
Old 05-06-2014, 01:16 PM Thread Starter
I'm not using a switch.
You can mount the switch anywhere you like.
As far as what type of switch, any two position switch, that is rated for over 12 volts and at least a 10 amp rating.
A few here have posted how to install it, and it's so simple it makes perfect sense.
The only thing the switch is doing is providing a complete circuit, via a ground, to the fan motor, since the switch is in front of the OEM's thermo/switch. That's why it doesn't negate the automatic feature of the thermoswitch to also kick the fan on.
All this is for SP1 only.
SP2's require a little different wiring, but still very easy.
Old 05-06-2014, 02:25 PM
extrapolator's Avatar
Quoted: 99 Post(s)
I think the manual switch needs to be beside ... aka parallel to ... the OEM thermo/switch.
If the manual switch was placed either before or after the OEM thermo/switch, your bike could get hot and try to turn on the fan, but the fan can't turn on whenever you have the manual switch off.
On the other hand, if the manual switch is beside the OEM thermo/switch, then either switch being on would cause the fan to run.
extrapolator is offline
Old 05-06-2014, 02:50 PM
Just did mine (SP2). I bought the fans without the oem connector, when I spiced my connectors on I added the wire for switch.
RC51 RIDER likes this.
grape ape is offline
Old 05-06-2014, 05:00 PM
ok am i missing something? spliced a wire into the single sensor wire that scews into the rad, grounded a wire to the frame and connected it to the ground spade on the switch. this is a 12vdc 30amp switch and i know its getting power and ground because there is a light on the switch that lights up red when you flip it on, yet my fan wont come on manually when i turn the ignition on. that third spade on the switch says accessory.
thaddeus is offline
Old 05-06-2014, 09:44 PM
anyone? i need to figure this out quick so i can get my bodywork back on.
thaddeus is offline
