New RC51, need to discover mods - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 13 (permalink) Old 06-05-2011, 03:49 PM Thread Starter
So the deal this weekend went pretty smoothly; brought my new 2002 home friday night and have been tooling all around town all weekend. Love! It!
The guy that I bought it from added an after-market windshield and exhaust. so I know it has a Yoshimura RS-3 exhaust and an aftermarket undertail kit. Few questions:
Attached is a photo of the undertail; can anyone identify what it is? I think it may be one of these: http://www.indysuperbikes.com/custom...&cat=0&page=16 , just by looks, but I'm not sure.
Similarly, does anyone know of a good kit that will add a light to the license plate? Indiana law requires it be lit. The little 'hump' on the right side underneath looks like it could be modified pretty easily or something bolted on to do just that.
Also, a few simple tests lead me to believe it has a speedo healer on it, but I can't say for sure. What's a quick way to tell?
Thanks guys. I look forward to riding and modding more.
BMah is offline
post #2 of 13 (permalink) Old 06-05-2011, 04:45 PM
Quoted: 38 Post(s)
that is a hotbodies undertail. The hump off to the right is where your ECU sits next to the battery (SP2's only).
The original connector for the license plat light should still be therelocated towards the rear of the rear cowl, its a small 2 wire white connector with a black/brown wire and green wire. Try to find the male end of the connector and wire it up to the light and you will be good. worst case if you cannot find a connector you can also hardwire it in.
As far as the speedohealer goes, open up the rear cowl and you should see it in there.
http://www.speedohealer.com/your_pics/sp1/tutorial.htm
Also see if you gearing has been changed, if it has chances are the speedohealer was done. The stock gearing is 16T front 40 on the rear sprocket.....look on the rear sprocket and you should see a manufacturer and number from 40-43.
gts455 is offline
post #3 of 13 (permalink) Old 06-05-2011, 05:04 PM Thread Starter
Great, that helps a lot, thanks. As for wiring the connector to the light, thats part of my problem. there isn't a light under there at all.
I'll go take a look at the other stuff right now.
BMah is offline
post #4 of 13 (permalink) Old 06-05-2011, 05:22 PM Thread Starter
Rear sprocket says "AFAM 11616-41", which from what you said before, I assume makes it aftermarket.
Under the rear seat, i have a white three-plug connector with black/tan, green/yellow, green wires going to it. I assume that's the one?
While what I saw in the back didnt exactly match the pictures from your link, the green zip ties, and the contents of a small black box with wires leading to the front leads me to believe that it does indeed have a speedo healer on it. This board look familiar?
BMah is offline
post #5 of 13 (permalink) Old 06-05-2011, 05:42 PM
Quoted: 38 Post(s)
that looks like a speedo healer or similair device to me.
The sprocket is aftermarket and you probably have 15T front.
No your looking at the brake/tail lights. It should just be a female end with no connection to it. If its not there, the previous owner may have cut it and capped it off since he was not using it.....if thats the case start looking where the rear lights link into the main factory harness and you should see green and black/brown wires (they could just be cut, taped up, or capped off)
gts455 is offline
post #6 of 13 (permalink) Old 06-05-2011, 05:43 PM
Quoted: 38 Post(s)
if the connector for the light is still there this is what it looks like
gts455 is offline
post #7 of 13 (permalink) Old 06-05-2011, 06:00 PM Thread Starter
Thanks. I'll keep poking around.
Even if I find it (or some other set of wires), there's no light underneath the tail to light the plate.
BMah is offline
post #8 of 13 (permalink) Old 06-05-2011, 06:38 PM
Quoted: 38 Post(s)
heres a few cheap ideas
http://cgi.ebay.com/ebaymotors/NEW-L...Q5fAccessories
http://cgi.ebay.com/ebaymotors/Unive...Q5fAccessories
or you could easily go to radioshack and put something pretty nice together.
the screw lights are probably the easiest thing for you to do, then all you have to do is run the wire to wherever that license plate light connector is and your in business.
gts455 is offline
post #9 of 13 (permalink) Old 06-05-2011, 08:56 PM
Just buy a self adhesive strip of white LED's - about 12cm long.
It should then be invisible unless switched on. 2 wires for power. Drill a small hole to feed the wire through, using a rubber grommet.
Test before connecting up. Use proper connectors, or solder & shrink fit.
Don't be tempted to twist wires and use electrical tape as a permanent solution.
Enjoy the RC!
post #10 of 13 (permalink) Old 06-05-2011, 10:28 PM Thread Starter
Yep, those would probably be the easiest ways to go about it. Ill tackle that sometime this week (I hope).
Thanks guys!
BMah is offline
