STM clutch slave cylinder - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 4 (permalink) Old 08-07-2014, 04:17 PM Thread Starter
Hi guys
I recently purchased a STM clutch slave cylinder to do away with the OEM unit.
Once fitted though it seems that the STM unit is not engaging the clutch enough. Ie the slave cylinder is not pushing the push rod through enough. The lever also doesn't seem to do anything until the last 1/2" of travel.
Has anyone else used the STM slave cylinder and came across the same problem? I know 'nobody' had this on his bike, but I can't seem to be able to pm him anymore.
Thanks in advance guys.
SP1 Jock is offline
post #2 of 4 (permalink) Old 08-07-2014, 11:50 PM
Nobody is gone mate as far as im aware, i know it may be a silly question but did you get all the air out of the line when you fitted her up. Also is it seated properly on the locator pins.
I only say this as mine took a bit of effort to tighten her down onto the locator pins, was a tight fit, but mine is a tsr slave cylinder.
Gardz is offline
post #3 of 4 (permalink) Old 08-08-2014, 01:59 AM Thread Starter
Yes mate. It was mounted flush to the casing and all air was bled out.
It's almost as if I need to put a 3-4mm packer inside the sleeve that drives the push rod.
SP1 Jock is offline
post #4 of 4 (permalink) Old 08-08-2014, 02:45 AM
Read here from post #41 and on
https://www.rc51forums.com/forums/sho...305#post551305
How many mm is your STM slave cylinder piston's O.D?
