installation question Tech G rearsets - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 9 (permalink) Old 09-12-2014, 04:06 PM Thread Starter
I'm ready to install my Tech G rearsets, but does anyone know, where are these two brackets with the large opening at the bottom of the rearsets for....found a pic of similar rearsets on speedzilla....and do I use the blue or red Loctite for the bolts.
Color01 is offline
post #2 of 9 (permalink) Old 09-12-2014, 04:38 PM
extrapolator's Avatar
Quoted: 99 Post(s)
Mid-pipe supports?
extrapolator is offline
post #3 of 9 (permalink) Old 09-12-2014, 04:53 PM
Yes, oem exhaust midpipe support. Some aftermarket exhaust may have that mount, others not.
post #4 of 9 (permalink) Old 09-12-2014, 04:59 PM Thread Starter
thank you, I was not sure...and my sato's don't have the support.
how about the loctite, blue or red
Color01 is offline
post #5 of 9 (permalink) Old 09-12-2014, 05:15 PM
blue imo, Red is considered permanent. Heat is needed to remove bolts/nuts with red lt.
post #6 of 9 (permalink) Old 09-12-2014, 08:45 PM
Yes, I have these. My LB pipes use those brackets, they are indeed mid pipe supports. Make sure you use the OEM rubber grommets if yours did not come with any. Blue is your loctite color too.
post #7 of 9 (permalink) Old 09-13-2014, 11:16 AM Thread Starter
send you a PM.
Color01 is offline
post #8 of 9 (permalink) Old 09-14-2014, 08:51 AM Thread Starter
Got them installed, But don't you need a Brake release spring....just incase.
Color01 is offline
post #9 of 9 (permalink) Old 09-14-2014, 12:36 PM
I sent you a pm.
