Airbox Volume - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 11 (permalink) Old 03-04-2015, 04:52 AM Thread Starter
Airbox Volume
Hey. Does anyone know the volume of the standard SP-1 airbox?
Lycon86 is offline
post #2 of 11 (permalink) Old 03-04-2015, 05:59 AM
Oz Rc51's Avatar
7 liters i believe, but I have also seen some specs say 10 liters but that may be without the airfilters just to make it sound better as a sales pitch..
Oz Rc51 is offline
post #3 of 11 (permalink) Old 03-04-2015, 08:08 AM Thread Starter
The reason I ask is, I've done the known mod to the standard airbox, and I've measured the volume at just over 8lt. So was wondering what the standard is for comparison.
Next thing is to Dyno it. Before mod was 127hp. be interesting to see what its like after I fit this airbox
Lycon86 is offline
post #4 of 11 (permalink) Old 03-05-2015, 04:33 PM
Quoted: 331 Post(s)
With a stock engine you are best off just leaving the OEM airbox installed.
post #5 of 11 (permalink) Old 03-05-2015, 04:46 PM Thread Starter
It is the standard airbox. Just modified slightly. Also engine isn't standard, it's blueprinted. Not hot cams and high compression positions, I know. This is why I didn't get a race airbox, I.e moriwaki.
Anyway. The dyno will be the judge of whether it's a worthwhile modification.
Lycon86 is offline
post #6 of 11 (permalink) Old 03-05-2015, 04:50 PM
Quoted: 331 Post(s)
Minor modifications like that are rarely perceived on a dyno. You have to get a dyno operator that is absolutely meticulous about how they make the runs and doing enough runs to see the power fall off to get the best runs of the lot etc. It is not as simple as just doing a couple dyno pulls to see the results.
Ambient variations and engine temp fluctuations alone can cause more disparity from one dyno run to another in back to back testing than the changes from modifying stock parts like airboxes. The chances of getting a conclusive result for what you are talking about is pretty much nil.
post #7 of 11 (permalink) Old 03-05-2015, 05:00 PM Thread Starter
Not in my experience. Ambient temp and operating temp are all noted and used as control. As the power on most bike engines tends to suffer, at anything anything over 85 degrees C. I've seen power gains as high as 15bhp from blue printing, intake and exhaust modifications. So I'm afraid I disagree with you saying this is pointless. Like I said. I'll post results when I get round to it.
Lycon86 is offline
post #8 of 11 (permalink) Old 03-05-2015, 05:05 PM
Quoted: 331 Post(s)
Without HC pistons and/or cams you won't see much of anything worth the effort on the RC51
post #9 of 11 (permalink) Old 03-05-2015, 05:15 PM Thread Starter
Yup. I realise that. why stop there? If I was going to do it right I'd also put some decent rods in and fit a Nova transmission? But I haven't got the spare cash for that and as I said before I'm doing what I can to a standard bike. And I have seen power gains. Nothing stellar. But it's something. Otherwise why bother doing anything, unless you want to throw 4 figures at it?!
Lycon86 is offline
post #10 of 11 (permalink) Old 03-05-2015, 08:53 PM
If you haven't already installed one, a power commander unit will the better option as you can improve the fuel/air ratios over the Rev range.
This is highly recommended for SP1's.
SubSailor is online now
