15/41 sprockets - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 19 (permalink) Old 02-19-2012, 10:46 PM Thread Starter
15/41 sprockets
anyone have the 520 15/41 sprockets? any significant improvements? im debating the upgrade so any insight is helpful.
2003 RC51 #152 of 2000
The Man Who Sleeps With His Bike
WarpSpeed is offline
post #2 of 19 (permalink) Old 02-19-2012, 11:29 PM
Check post #46 here as a reference on the sprocket's teeth. Yet, I have never used a 520 on my RC......maybe I try the 525 at some point but I am not sure yet!
post #3 of 19 (permalink) Old 02-20-2012, 02:11 PM
Quoted: 331 Post(s)
Jesus Howard Christ dude... Thousands upon thousands of RC owners have switched to the 15/41 520 Conversion just do it I mean it's not like this is a life threatening decision that is going to prevent your kids from growing up and quitting college on you or anything significant...
post #4 of 19 (permalink) Old 02-20-2012, 02:34 PM
Waldo's Avatar
Quoted: 40 Post(s)
I can see an issue if you are using some second rate 520 chain. If you get a good quality (DID for me) chain, the 520 is no problems. I abuse the hell out of mine and it holds up fine.
Waldo is offline
post #5 of 19 (permalink) Old 02-20-2012, 03:57 PM Thread Starter
Ok first off watch your mouth. I said any insight is helpful. Secondly... I FOUND WALDO! thirdly I'm not made of money so if the upgrade isn't significant then what's the point? Lastly I have no children and I hope you don't as well because I can only imagine the amount of patients you would show them.
post #6 of 19 (permalink) Old 02-20-2012, 04:01 PM
vfrsam's Avatar
I have 15/42 with 520 and love it.
vfrsam is offline
post #7 of 19 (permalink) Old 02-20-2012, 04:05 PM
Quoted: 331 Post(s)
The difference between stock gearing with a 530 chain and a 15/41 520 Conversion is probably the one mod that will make the most noticeable difference of ANY mod you ever do to your RC51.
The only thing that might surpass that gearing mod in terms of the difference you feel might be the Ohlins shock out back, but even then the 15/41 is a huge improvement.
Sprocket & Chains are routine maintenance for a motorcycle not just an upgrade.
post #8 of 19 (permalink) Old 02-20-2012, 05:08 PM
rc51anthony's Avatar
15/41 with 520 DID and love it. 190/55 tire ,, used to have 15/40 was ok ,,, but 15/41 love it
  • Moriwaki rearsets
  • Power Commander USB
  • DID 520 gold chain
  • CRG folding clutch lever
  • Flapper PAIR EVAP removed
  • Soft Rev limiter removed
  • 15/41 gears 520
  • Vortex clip-ons
rc51anthony is offline
post #9 of 19 (permalink) Old 02-20-2012, 05:22 PM
rvtjonny's Avatar
+1
BTW...
You know the search on this forum is quite useful and would have given you plenty of fed back without being out in the open with the firing squad.
rvtjonny is offline
post #10 of 19 (permalink) Old 02-20-2012, 05:42 PM
Super Moderator
YtseJam's Avatar
Quoted: 18 Post(s)
You know, for some reason around here...when these kind of posts pop up from LDH, it's no problem because he is this bike "super guru gets paid for his opinions"..blah blah blah. Finding experts who have differing opinions on certain subjects isn't that hard. I welcome anyones opinions, and his MAY be more informed than others.... but do you think LDH you could work on your delivery? You and I have gone at it because of this same thing, and it's old....+1 WarpSpeed.
YtseJam is offline
