master cylinder question - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 2 (permalink) Old 03-03-2012, 01:11 PM Thread Starter
Posted on Speedzilla but I think it's better asked on this forum.
Did a search hard to decipher...but sorry if its a re-post.
Can you use Brembo radial master cylinder on stock brakes in the meantime, until a caliper upgrade or do you have to go to radial mounted brakes with the swap?
Thanks
post #2 of 2 (permalink) Old 03-03-2012, 03:24 PM
rc51anthony's Avatar
yes the brembo master will work with stock calipers , just use braided lines . i have that set up now , and 100 times better
  • Moriwaki rearsets
  • Power Commander USB
  • DID 520 gold chain
  • CRG folding clutch lever
  • Flapper PAIR EVAP removed
  • Soft Rev limiter removed
  • 15/41 gears 520
  • Vortex clip-ons
rc51anthony is offline
