Re: rear sprocket hub - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 5 (permalink) Old 06-27-2015, 12:46 PM Thread Starter
Hey guys, can I shorten the RC rear sprocket hub for a wheel swap to a project?
Rickman is offline
post #2 of 5 (permalink) Old 06-28-2015, 07:31 AM
Quoted: 135 Post(s)
Anything is possible...do you know where/what you want to remove?
sbkdrew is offline
post #3 of 5 (permalink) Old 06-28-2015, 09:55 AM Thread Starter
I am installing a RC wheel in a Rickman, and need the sprocket closer to the wheel by an inch
Rickman is offline
post #4 of 5 (permalink) Old 06-28-2015, 01:51 PM
Quoted: 135 Post(s)
Are you sure offsetting the chain closer an inch will clear the tire?
I'm thinking with some mods you might be able to flip the sprocket and mounting studs and mount the sprocket on the side the studs mount against along with some washer type spacers to adjust the difference.
All that is without looking at one right now though ..
sbkdrew is offline
post #5 of 5 (permalink) Old 06-28-2015, 01:59 PM Thread Starter
I am worried about using washers behind the sprocket, I am thinking power to the sprocket might break the mounting bolts, what other mods do you think I could do?
Rickman is offline
