Moriwaki Engineering Thermo delete install help - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 1 (permalink) Old 05-09-2016, 02:01 PM Thread Starter
Quoted: 34 Post(s)
Does anyone have a pic of the correct alignment of the Mori delete adapter and the two hoses.
(Front cylinder head is on the left of pic)
Roger Ditchfield told me that the Moriwaki part will sit properly between the cylinders with no kinks in the small hoses to the cylinder water jackets. But during test fitting, there appears to be a few different ways it can fit. The two black hoses I cut per the Mori instructions that Roger gave me;
Roger said the threaded hole in the Moriwaki part is to insert the OEM temperature sensor.(Is that the sensor off the OEM thermostat?)
I need to know which way the aluminum adapter needs to face. If anyone has installed this please send a pic or drawing.
I tried to find the original Moriwaki Engineering Manual online but no luck.
ezno is offline
