Blackbird kickstand - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 3 (permalink) Old 07-25-2019, 12:07 PM Thread Starter
twag4's Avatar
Blackbird kickstand
After changing to a 190/55 rear tire, my bike leaned and only required about 15-20 lbs of pressure pulling handlebars or seat towards side stand to make the back wheel hover off the ground. I modded a blackbird stand as others before me have done, and am happy with the result. Stand also sticks out a bit further, making a larger triangle between it and the two wheels. Because of this, it is much more stable. It doesnít sit flat on the surface like the stock one would, so Iíll see how it fairs with asphalt. It may require some heat and a bit of bending if itís a problem. Anyway, here are some pics, welded a spring tab made out of thin 1/8Ē strapping, with a notch for spring retention.
ID:	130883   Click image for larger version
ID:	130885   Click image for larger version
ID:	130887   Click image for larger version
twag4 is online now
post #2 of 3 (permalink) Old 07-25-2019, 08:46 PM
Quoted: 64 Post(s)
Thanx for posting this, I'm putting a 2x4 under mine right now, so looks like it would help me, what year(s) Blackbird? Did you use the Blackbird switch or move the RC one over?
BadToTheBown is offline
post #3 of 3 (permalink) Old 07-25-2019, 09:19 PM Thread Starter
twag4's Avatar
I got a first year blackbird stand. The only part i used was the stand itself. I retained my original spring, switch, switch mounting bolt, stand bolt, and nut.
twag4 is online now
