Billet short velocity stacks - Honda RC51 Forum : RC51 Motorcycle Forums
 9Likes
post #1 of 15 (permalink) Old 07-26-2016, 01:51 PM Thread Starter
Quoted: 4 Post(s)
2 Sets of short (25mm) billet alu. velocity stacks, 1 for SP1 (back pair), 1 for SP2 (front). Made from EN AW 2007 alu. To be used with aftermarket airboxes like Durbahn, T1, DHC, Moriwaki.
I think they can be used with the oem airbox, I will supply 4 bushings to hold the oem airbox down. (If I remember correctly the bolts for the oem stacks also hold the airbox down).
Price is 200$ US per set (incl. shipping).
SP1:PVM mag.,full Akra,Durbahn airbox,T1 G2 snorkel,SpeedCell,SP2 swing+mod. subfr.+engine cover,WP susp. +TiN,endur. fairing VFR400 headlight,KYA fronts, Setrab oilcooler,MR clipons,flowed throttlebod.,lightened flywheel, Moriwaki rests, Delrin stacks,BKG triple clamps,PC II,Ti bolts, qr seat+tank,Durbahn/ISR rear brake,Durbahn CCC,AFAM 15-41, DID520,CBR600RR coils,50310 fan switch,mod. wire harness,HRC overflow,Extreme Graphics undertray,Harris fairing stay.
SPeter1 is offline
post #2 of 15 (permalink) Old 01-27-2017, 02:47 PM
kneedownb's Avatar
Hi,
Are you still turning out these velocity stacks?
If so, do they fit and work in a standard air box?
Can you turn some for the standard air box, or what do you recommend?
Cheers!
kneedownb is offline
post #3 of 15 (permalink) Old 01-27-2017, 04:46 PM
CapeCodderRC's Avatar
Quoted: 114 Post(s)
ID:	114138They don't fit in a OEM airbox
Clint / 2000 RC51 #414
CapeCodderRC is offline
post #4 of 15 (permalink) Old 01-28-2017, 04:44 AM Thread Starter
Quoted: 4 Post(s)
As I have sold my oem SP1 airbox I am not able to check if they will fit.
The longer stacks will not fit the front throttle body because the air filter is in the way, but I thought 2 short stacks will fit or a short stack on the front and a longer in the rear (identical to oem)?
SPeter1 is offline
post #5 of 15 (permalink) Old 01-28-2017, 06:19 AM
Quoted: 55 Post(s)
Why dimples in a non rotational object? It is true that dimples (as discovered during the dam busting bomb design) allowed a golf ball to go nearly twice as far as a smooth ball by inducing a rotation but why in a static item? Planes dont have dimples.
Way2Slooow is offline
post #6 of 15 (permalink) Old 01-28-2017, 07:03 AM Thread Starter
Quoted: 4 Post(s)
I just copied the idea from HRC and Thorsten Durbahn.....
SPeter1 is offline
post #7 of 15 (permalink) Old 01-28-2017, 07:15 AM Thread Starter
Quoted: 4 Post(s)
To answer the HRC throttle body question - Speedzilla Motorcycle Message Forums
SPeter1 is offline
post #8 of 15 (permalink) Old 01-28-2017, 08:44 AM Thread Starter
Quoted: 4 Post(s)
The dimples do not induce a rotation, it is because of the rotation that more dimples come in contact with the air that passes over the object. As I understand it, the dimples create a boundary of turbulent air, that reduces the resistance of the air flowing over this layer of air. However at higher speeds this effect reverses, maybe that is why plane don't have dimples?
MIT study:
Morphable surfaces could cut air resistance | MIT News
SPeter1 is offline
post #9 of 15 (permalink) Old 01-28-2017, 09:34 PM
Quoted: 55 Post(s)
Fair enough....I watched a program on the Dam Busters once (where they say the dimple idea originated) and they couldn't get the bombs to behave the way they wanted....skip across the water. The bombs would simply hit the water, bounce maybe once or twice and sink. In this particular case the dimples were added and the desired affect was achieved. They then used the process on golf balls and as mentioned the balls went nearly twice the distance. I was hoping you had found a benefit....... Have you tried them against ones with no dimples?
The MIT article was very interesting
post #10 of 15 (permalink) Old 01-29-2017, 03:04 AM Thread Starter
Quoted: 4 Post(s)
I have no data for the stacks with or without dimples, I just copied the idea and let my customers decide. Almost all liked the dimples so that's how I make them. Maybe the dimples work at lower rpm/air speeds and then the short stack comes into play at higher rpm?
I suspect HRC have done their homework, although maybe for our more standard RC's its more cosmetic?
If you are interested in bell mouth shapes there is an interesting article on the internet by Prof. Blair of QUB, he suggests that an elliptical shape of the stacks is the best. As soon as I will be able to do some machining again (my recovery from surgery on a broken hip is not going to plan...) I plan on trying this. At the moment I use a radius of 25mm, that's the largest I can do on my lathe and mill.
SPeter1 is offline
