Replacement Ohlins axle washer - Honda RC51 Forum : RC51 Motorcycle Forums
 3Likes
  • 2 Post By Denver_larry
  • 1 Post By JNSD
post #1 of 7 (permalink) Old 10-14-2017, 07:59 PM Thread Starter
Quoted: 15 Post(s)
The forks I bought were missing the original washer that goes between the axle bolt and the right fork leg. NLA available from Ohlins, so I had one made for myself and decided to ask for a few more in case others were in the same predicament. I can finish it a few different ways if you wish: raw machined, sanded to a satin finish (shown below), bead blasted, or polished. 38mm OD, 2.8mm thick. $20 shipped
kwtoxman and zana403 like this.
Denver_larry is offline
post #2 of 7 (permalink) Old 10-15-2017, 06:00 PM
Quoted: 25 Post(s)
I didn't know it until I looked, I need one of these...
nunya is offline
post #3 of 7 (permalink) Old 10-15-2017, 09:00 PM
JNSD's Avatar
Quoted: 17 Post(s)
Are you using the oem bolt? Mine is different for some reason....
JNSD is offline
post #4 of 7 (permalink) Old 10-16-2017, 10:02 AM
Quoted: 25 Post(s)
I have a Ti64 axle and bolt, which looks like the picture Larry posted above. I do have the OEM bolt like yours someplace but never noticed the difference in diameter of the flange.
nunya is offline
post #5 of 7 (permalink) Old 10-16-2017, 10:58 AM
Quoted: 326 Post(s)
the fg322 have a different setup than the fg832, so not all people with ohlins forks will have this washer.
if you have the 832s (with the axial mounting system for the caliper brackets) then this applies. if you have the 322 (with the radial mounting system for the caliper brackets) then this does not.
post #6 of 7 (permalink) Old 10-16-2017, 11:57 AM
Quoted: 25 Post(s)
I have the FG322 which has an OEM bolt with flange that would negate the need for this washer; however, I'm using an aftermarket bolt that has a smaller flange so this washer may still prove useful until/unless I have a different aftermarket bolt machined.
nunya is offline
post #7 of 7 (permalink) Old 10-16-2017, 12:48 PM
JNSD's Avatar
Quoted: 17 Post(s)
Good to know. Thank you
CapeCodderRC likes this.
JNSD is offline
