DIY Fork spring tool. - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 3 (permalink) Old 06-22-2013, 09:31 PM Thread Starter
TNRC51's Avatar
I'm in the process of doing a fork rebuild thanks to the earlier post. I had an idea for a fork spring tool that I thought I would share. Since I already had the floor jack I scrounged an old shelf leg out of the warehouse at work. I got a scrap piece of steel tube from one of the plants I work with. The only thing I paid for was a piece of threaded rod. So I have about $3 invested. I think a steel pipe coupling would work and be a cheap substitute for the steel ring.
'04 Nicky Hayden
Flapper/PAIR Mod-Ladybird Full Ti Moto-GP -w- Long Cans-Proton Flushmount LEDs
HotBodies Undertail-Tyga CF Hugger-HEL Lines
Custom plate mount w integrated LED brake light
15/41 gearing-PCIII USB-Speedohealer-Carbone Lorraine Pads
Spencer Seat mod-Ceramic dual coat headers
It is a wise man who knows where courage ends ...
and stupidity begins.
TNRC51 is offline
post #2 of 3 (permalink) Old 06-23-2013, 07:01 AM
lyfsux's Avatar
That is a good idea. My question is to replace the seal is it necessary to remove the whole assembly from the triple tree? I just had mine replaced and he just pulled the slider out on the bike. I only ask this because I have a thread started on the tech talk I have a leaking fork seal still after having it replaced twice in less that a week?
2000 sp1 number 000039
full hindle off-road exhaust
power commander
double bubble screen
sprocket swap 1 down 3 up
k and n filters
and now flapper mod thanks to rc forums
lyfsux is offline
post #3 of 3 (permalink) Old 06-23-2013, 07:46 AM Thread Starter
TNRC51's Avatar
If your seal is gone likely the upper and lower bushings need to be replaced as well. At least the lower. I'll post a pic of mine but over half of the copper was gone. I'm also replacing all the o-rings. Taking the fork out is really not bad at all.
'04 Nicky Hayden
TNRC51 is offline
