Tidy relays mod - Honda RC51 Forum : RC51 Motorcycle Forums
 3Likes
post #1 of 14 (permalink) Old 05-07-2018, 01:25 PM Thread Starter
Quoted: 15 Post(s)
I know this might not be a big deal but it actually clean the inside of my trunk and I think it’s worth sharing/doing.
Cheapmods is offline
post #2 of 14 (permalink) Old 05-07-2018, 02:01 PM
i did something similar but built a bracket on the outside of the subframe and used mountable relays to put them all in once place. cleans up the trunk a ton.
post #3 of 14 (permalink) Old 05-07-2018, 04:55 PM Thread Starter
Quoted: 15 Post(s)
Nice, I made mine off the relay holder from 04-06 600rr.
Reason I have’em inside the subframe is so I won’t have to worry about contact when taking off the tail plastic. There’s alread R/R and starter relay on the left and cdi on the right side.
jondog9 likes this.
post #4 of 14 (permalink) Old 05-07-2018, 05:06 PM
i know, i have the same bike.
i have my 3 relays in the back out of the way, then the RR then the starter relay relocated slightly (due to RR relocation when i swapped to a shindengen)
on the right i have my kls QS box, my CDI and my PCV
the only thing that causes trouble with fitting the tail section is the lame OEM brake fluid reservoir. if you get rid of that nothing else causes any grief.
putting everything on the outside makes for a tidy trunk. i also consolidated my turn signals and license plate light into a single 4 pin connector.
post #5 of 14 (permalink) Old 05-07-2018, 05:22 PM Thread Starter
Quoted: 15 Post(s)
Ohhh you have 03-06 600rr too? Nice!!!
actually I know you were talking about your RC. I was just playing dumb, it just that I don’t know if you’re being sarcastic or stating the obvious (which would also fall under sarcasm).
Anyway...Yep... I’ll be relocating the rear reservoir to 08+1krr mod. I’m not doing crf or hrc delete cuz than I’d be flushing the rear more often.
post #6 of 14 (permalink) Old 05-07-2018, 05:26 PM
i know, i was just laughing at your explanation of where parts are on the bike.
no reason to flush more with a CRF master, you may have to top up a bit as the pads wear but i doubt that even.
post #7 of 14 (permalink) Old 05-07-2018, 05:27 PM Thread Starter
Quoted: 15 Post(s)
Dammm ... you can build a swimming pool in there wibb.
post #8 of 14 (permalink) Old 05-07-2018, 05:35 PM
could probably fit a six pack?
post #9 of 14 (permalink) Old 05-07-2018, 05:36 PM Thread Starter
Quoted: 15 Post(s)
Originally Posted by Wibbly View Post
.... i also consolidated my turn signals and license plate light into a single 4 pin connector.
Ha... that’s what it is. I was trying to figure out what those 4 prong connector was...great job!!
post #10 of 14 (permalink) Old 05-07-2018, 05:42 PM Thread Starter
Quoted: 15 Post(s)
Before I got my SPs, my wife want me to bring some to-go food after bike night. Well, buddy of mine offered me to put it in the trunk cuz it would definitely not fit in my R1, and I don’t believe him till we stuck it in there. It was so spacious that I believe we could fit another to-go box. So yea 6tall-boys would most likely fit in there too. lol
