Troubleshooting help - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 4 (permalink) Old 05-07-2018, 10:50 PM Thread Starter
Unhappy Troubleshooting help
Hello all,
any assistance you can provide is greatly appreciated.
04RC start cutting out then eventually died. Got the 8 blinks (TP sensor), check the sensor and connector so far on that end there seems to be no connectivity issues and not corroded either. I tried clearing the MIL FI, hoping this would fix the issue but no luck. I'll follow the rest of the wires this weekend especially the PCIIIr, since I have the PCIIIr though are there any thoughts/ideas on how to proceed or other things to check. Should I reload the PCDIIIr map?
Background, this started worsening after a track day. When I cleaned the air filters, decided to check the plugs and notice the rear is loose, also found out my negative battery connection came loose. I just changed new plugs and tightened the battery cables. Thanks.
BIKES:
02 F4I TRACKBIKE(SOLD)
04 RC51 (BABY)
98 F3 (Acquiring 2/9/13) TRACK
"Lead me not unto temptation,
I can find the way myself"
3stan is offline
post #2 of 4 (permalink) Old 05-07-2018, 11:04 PM
Remove the pc3.
post #3 of 4 (permalink) Old 05-07-2018, 11:12 PM Thread Starter
Wibbly, thanks I'll try that this weekend.
BIKES:
04 RC51 (BABY)
3stan is offline
post #4 of 4 (permalink) Old 05-07-2018, 11:29 PM
thing is, the TPS signal goes through the power commander, so the fact you have a tps code suggests it's not getting to the ECU as it should.
best thing is to eliminate anything between the sensor and the ecu. so start there. chances are that's all it is.
