Suspension way too stiff! - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 15 (permalink) Old 02-16-2013, 06:30 PM Thread Starter
I bought my RC51 about 4 months ago from a guy who was quite a bit heavier than I am. I weigh about 165 and he was probably around 230. So the suspension is very stiff, there is hardly any travel at all.
My question is how do I soften the suspension up so it will actually do its job? Or maybe a better question is what do I need to do in order for it to be a more comfortable ride? Is it likely that I need to do spring adjustments as well as compression and rebound?
Thanks,
Joe
Jobo is offline
post #2 of 15 (permalink) Old 02-16-2013, 06:49 PM
Depends if the suspension is stock or not. Need that info.
post #3 of 15 (permalink) Old 02-16-2013, 06:51 PM
Sp1 or sp2 ????
post #4 of 15 (permalink) Old 02-16-2013, 07:23 PM Thread Starter
Oh my apologies
2002 RC51
Front forks are Showa MCF-A21
I think the rear are stock.
Thanks,
Joe
Jobo is offline
post #5 of 15 (permalink) Old 02-16-2013, 07:45 PM
Back off the preload front and rear and if it is stock that should help. Read the manuals on rc51.info if you need help. Also lower the compression damping front and rear and it will work better with your body weight. FWIW, the RC51 is on the stiff side the way it came.
post #6 of 15 (permalink) Old 02-16-2013, 08:59 PM
JusAnadaMexican's Avatar
Save your pennies and get a good rear shock kit, that'll definitely boost your confidence on the bike. For now like the others say, soften up the pre load on both shocks. I would click to the softest possible and start setting it from there. Good luck man
2001 rc51 upgraded
2006 650R Ninja sold
JusAnadaMexican is offline
post #7 of 15 (permalink) Old 02-16-2013, 09:26 PM
Use this as a guide...
Reset your suspension with the help of a friend and you should be okay.
If not, this should be the first step and then maybe check the spring sizes while changing the fork oil.
As for the stock shock, okay for a little guy but virtually useless to a guy over 200#
Good Luck
post #8 of 15 (permalink) Old 02-16-2013, 09:54 PM
Clutchless45's Avatar
Suggested Sportbike Suspension Settings
Sport Rider's setup recommendations for every motorcycle tested from 1997 on.
January 21, 2013
I used this as a baseline for my RC and CBR when I first brought them home. I made minor adjustments from there but overall it was pretty good. If you still have stock shocks that is. If not the videos on You Tube like Madbuyer suggested will walk you through the complete process.
you have to scroll down a lil bit to get to the Honda secction.
http://www.sportrider.com/suspension...s/viewall.html
Colt
00 RC51 #1119
97 CBR F3
Clutchless45 is offline
post #9 of 15 (permalink) Old 02-18-2013, 09:32 PM Thread Starter
Thanks so much to everyone who posted! I really appreciate the help!
Jobo is offline
post #10 of 15 (permalink) Old 02-18-2013, 10:42 PM
Originally Posted by madbuyer View Post
Sp1 or sp2 ????
Hate to thread jack...but MB your avatar is giving me the heebee jeebee's. *shudders....
