Quick forks question - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 8 (permalink) Old 03-01-2013, 09:57 PM Thread Starter
SwiftTone's Avatar
Could the outer tube rotate independently from the inner tube? The reason I'm asking because the set of forks I'm interested in has scratches on one side of the outer tube, so I'm wondering if I can rotate it so the scratches are hidden.
Thanks
SwiftTone is offline
post #2 of 8 (permalink) Old 03-01-2013, 10:32 PM
Yes, they rotate freely.
post #3 of 8 (permalink) Old 03-02-2013, 12:06 AM Thread Starter
SwiftTone's Avatar
Second question: what size is the axle nut for the forks?
Thanks
post #4 of 8 (permalink) Old 03-02-2013, 01:07 AM
I think it is a 22mm any one else?
post #5 of 8 (permalink) Old 03-02-2013, 02:17 AM
Yeap....22mm spanner and 22mm axle diameter.
post #6 of 8 (permalink) Old 03-06-2013, 02:17 PM Thread Starter
SwiftTone's Avatar
Thanks guys.
If I want to take the forks off, are there any special tools needed?
Also, if the outer fork tubes are scratched, will they corrode?
post #7 of 8 (permalink) Old 03-06-2013, 02:36 PM
A good torque wrench.
Couple tips:
Don't let the brake calipers dangle on their hoses, support them somehow.
Clean the threads of the triple clamp bolts and use blue locktite. 20 lbf.ft
And follow b.miller123 processs for putting the front wheel back on.
Originally posted by b.miller123
I replied to your PM just now, but I'll post up here since it might help with any confusion that other have with installing the front wheel. If you have any other issues, let me know and I'll help you out. To clear up and confusion, these are custom spacers I made for these wheels to fit the RC51 (they are originally for a CBR929/954).
The SP1 and SP2 both use the same wheel spacers, bearings, axle and center collar (the part that goes in between the bearings inside the wheel)
The procedure for installing the front wheel is as follows:
Take the wheel, put the spacers on and put it in between the forks and slide the axle through.
Install the axle bolt on the right side and torque to 43 ft lbs
Install the axle clamp bolts on the right fork and torque to 16 ft lbs
Install calipers and torque bolts to 22 ft lbs
Put the bike (or at least the front end) down on the ground and hold the brake while pumping the forks down and back up a few times to seat the axle.
Make sure the index line on the left side of the axle is aligned with the outer surface of the fork leg.
Install the axle pinch bolts on the left fork leg and torque to 16 ft lbs.
The reason for "seating" the axle is because the left fork leg basically floats on the axle until the pinch bolts are tightened. This is done to prevent the forks from being pinched or spread at the lower end vs the upper end. If this is not done, there will be additional friction between the fork sliders (chrome part) and the bushings inside of the upper fork due to them not being aligned perfectly. When you bounce the forks, it allows the left fork leg to move to the correct spot on the axle.
When you install the axle bolt on the right leg and torque it down, the thicker portion of the axle (on the left side of the axle) is mated to the left spacer. This means that when you torque it down, all of the spacers and bearings are pulled tight to the right fork. At this time, you can still take the left fork leg and move it back and forth. It looks like there is a gap between the spacer and the fork because there is. The left spacer doesn't sit against the fork, it sits against the thicker portion of the axle. In the picture above, you are seeing the axle in between the spacer and the fork. This creates the illusion that there is a gap. The easiest way to visualize this is the install the axle in the wheel and just the right fork leg (you can spin the bottom of the fork around and put the bolt in and tighten it all up).
__________________
SP2 Part Out
2011 Bike of the Year
post #8 of 8 (permalink) Old 03-06-2013, 07:06 PM
Originally Posted by SwiftTone View Post
Thanks guys.
They will corrode if salt gets in there. Clean up the area and mask it off and spray some rattle can clear on it to give it a good coating.
