Suggest Fork Settings for 180lb rider - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 10 (permalink) Old 05-19-2014, 10:43 PM Thread Starter
GWS
GWS's Avatar
Quoted: 13 Post(s)
Last week I replaced the fork seals, bushings, and oil, and I was wondering if anyone can give me some basic suspension settings for my weight. I did a careful job on the fork work, and I followed the directions in the how-to section closely, and I made sure I used Honda's SS8 10W fork oil, and set the level to 135mm.
After doing the work I reset the the fork dials to their previous places;
preload 7 turns clockwise
rebound 3 1/4 turns clockwise
compression 12 clicks clockwise.
I took a ride and put a zip-tie on the fork tube and noticed that without any hard breaking or crazy bumps by the end of the ride it was within 1/2 inch from bottoming out. This seems like too much travel to me, but what do you guys think? I am 180lb before gear, could you guys suggest moderately aggressive settings for my weight? I do track days a few times a year.
GWS is offline
post #2 of 10 (permalink) Old 05-19-2014, 10:51 PM
Set your sag with preload, ride and recheck suspension travel used. Add compression damping to make the fork more resistant to compression.
google rc51 sportrider settings for a comp/rb setting comparison.
FWIW a good set up uses nearly all travel without bottoming out.
post #3 of 10 (permalink) Old 05-19-2014, 11:45 PM
weyrauchrc51's Avatar
Quoted: 10 Post(s)
There is no specific "setting" for 180lbs, but your preload setting will be different based on your weight.
Like KW said, set your sag first (with gear on and forks warmed up)...then adjust from there.
2001 SP1 (sold)
2004 SP2 (properly stored)
2012 Ruckus (stolen)
Semper Fidelis
weyrauchrc51 is offline
post #4 of 10 (permalink) Old 05-20-2014, 01:54 AM Thread Starter
GWS
GWS's Avatar
Quoted: 13 Post(s)
Thanks for the Sportrider chart information. I will start there. Question; when measuring the suspension settings, do I measure from fully CW (soft) or CCW (hard), for all three adjusters?
GWS is offline
post #5 of 10 (permalink) Old 05-20-2014, 08:35 AM
Quoted: 10 Post(s)
You should always start with fully closed and work your way out (for compression and rebound). Sag settings will be based on your weight (recommend with gear and suspension warmed up)...and adjust based on mm.
2001 SP1 (sold)
Semper Fidelis
post #6 of 10 (permalink) Old 05-20-2014, 03:19 PM Thread Starter
GWS
GWS's Avatar
Quoted: 13 Post(s)
I just went for a ride after using the Sportrider settings and the bike felt much better, and there was much less front end dive. Thanks guys!
GWS is offline
post #7 of 10 (permalink) Old 05-20-2014, 04:48 PM
Quoted: 10 Post(s)
Great news. What settings did you end up settling with?
2001 SP1 (sold)
Semper Fidelis
post #8 of 10 (permalink) Old 05-20-2014, 11:04 PM Thread Starter
GWS
GWS's Avatar
Quoted: 13 Post(s)
Rebound Damping to 2 turns from fully CW
Compression damping 8 clicks from fully CW
Pre-load 7 turns from full soft
Now the dimples on the Rebound Damping Screws face each other, where as before they were totally off in different directions, so possibly measuring from fully CCW like I originally did will not result in they being the same for both forks. Either way the bike feels way better now.
GWS is offline
post #9 of 10 (permalink) Old 05-21-2014, 11:32 AM
Rebound and compression settings, always start from full closed - clockwise - then count the clicks as you go softer - counterclockwise.
post #10 of 10 (permalink) Old 05-21-2014, 08:03 PM
Hondad's Avatar
Quoted: 5 Post(s)
This is a David Moss video. For setting sag and rebound.
GWS
What is your sag?
Hondad is offline
