Installed DK link but shock now hits swing arm - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 32 (permalink) Old 07-24-2014, 01:22 PM Thread Starter
GWS
GWS's Avatar
Quoted: 13 Post(s)
I just installed a HO204 and a DK link on my 2003 SP2, and I noticed that now everything is together the shock spring is so close to the swing arm that the two could touch. I took a really long look and I don't think they are touching now, but only because of the way the spring happens to be rotated, and I think that the weld on the swing arm actually extends between the coils near the bottom. This is something I was not expecting to deal with. I called Dan Kyle, and Marc suggested this spring 1092-36/105 for my weight with a DK link, I weigh 182lb before gear. The spring seems really big for me, and that could possibly be the reason it is touching.
I can't be the first person to have this problem, so how have you guys overcoming this issue?
GWS is offline
post #2 of 32 (permalink) Old 07-24-2014, 01:39 PM
wingnutt's Avatar
Quoted: 58 Post(s)
Mine is super close and I think if my spring were rotated it could touch.
yours touches try rotating the spring.
I will do your sidestand for free...
wingnutt is offline
post #3 of 32 (permalink) Old 07-24-2014, 02:20 PM
How's the shock's height adjuster? Could you take a picture underneath were the rebound dumping knob is located on the shock?
The shock's upper mount, how is it placed on the frame? It's not the same either way
post #4 of 32 (permalink) Old 07-24-2014, 02:52 PM
Should I send mine as well ?
DuckHunterComposites
Duckhunter is offline
post #5 of 32 (permalink) Old 07-24-2014, 03:39 PM
Quoted: 332 Post(s)
When did you call them?
Is the spring rubbing the swingarm or not?
post #6 of 32 (permalink) Old 07-24-2014, 03:48 PM
wingnutt's Avatar
Quoted: 58 Post(s)
Sure why not
wingnutt is offline
post #7 of 32 (permalink) Old 07-24-2014, 06:50 PM
Quoted: 135 Post(s)
Usually the best solution is to remove the swing arm and grind back the weld a little bit so it clears the spring.
sbkdrew is offline
post #8 of 32 (permalink) Old 07-24-2014, 10:12 PM Thread Starter
GWS
GWS's Avatar
Quoted: 13 Post(s)
Here are the pictures you requested. What do you mean about the shocks upper mount not being the same either way?
Do you think I would have more room if I shortened the shock to reduce the ride height?
Let me know what you see...
GWS is offline
post #9 of 32 (permalink) Old 07-24-2014, 10:17 PM Thread Starter
GWS
GWS's Avatar
Quoted: 13 Post(s)
I called them 4-5 weeks ago when I first purchased the shock. I think I talked to Mark; I called Dan Kyle and told the lady I had an RC51, and she said "I'll put you through to our resident RC expert!" He told me I need this spring (which seems HUGE to me), and that if anything it could be on the under-sprung side for track use. What do you think about this spring rate (1092-36/105) for my weight; 182lb before gear?
This spring is not rubbing now, but I am confident that it will hit under normal street use.
GWS is offline
post #10 of 32 (permalink) Old 07-24-2014, 10:21 PM Thread Starter
GWS
GWS's Avatar
Quoted: 13 Post(s)
Good to know about the sidestand, thanks for the offer, I will likely take you up on it!!! I haven't taken it off the rear stand yet, but it looks a lot taller lol
What size spring do you have on your shock, and what is your weight?
GWS is offline
