What to look for when inspecting forks - Honda RC51 Forum : RC51 Motorcycle Forums
 2Likes
  • 1 Post By madbuyer
  • 1 Post By BTF/PTM
post #1 of 8 (permalink) Old 11-25-2015, 12:45 PM Thread Starter
Quoted: 17 Post(s)
Hi all,
This is probably a dumb question, but I'm gonna ask it anyway. Are there any tricks or tips to inspecting the forks after a crash?
The forks on Bella seem to be fine (we crashed this summer), there isn't any visible damage, the seals aren't leaking, and during a push-test the bike tracked straight and both forks compressed and decompressed evenly and smoothly when the brake was applied.
Is there anything else to look for?
Thanks!
2006 Black Edition SP2
- Stickerless black...giggity
- Assorted stone chips
- Multicolor bug splats, updated weekly
- Custom boot scratches and crash marks on the tailpiece
- Scuffed bar weights & brake lever from asphalt acrobatics
- Road grime under the fender and tail
- Leo Vince exhaust
- Otherwise OEM, not gonna make BOTY any time soon
HOE-LEE SHEE-YIT, the TORQUE!!!
BTF/PTM is offline
post #2 of 8 (permalink) Old 11-25-2015, 07:26 PM
take the fork legs apart and roll the stanchions on a flat surface, such as a glass table - to see if they're true. Other damage such as scratches or corrosion would be visible too.
Usually it's the stanchions that bend in an accident, but the aluminium legs can bend too, should be easy to spot the fractures if so.
HTH
post #3 of 8 (permalink) Old 11-25-2015, 10:22 PM
Take them apart and check the run out of the stanchions with one of these
and a couple of these
on what you know to be a level flat table.
jondog9 likes this.
post #4 of 8 (permalink) Old 01-29-2016, 12:27 PM Thread Starter
Quoted: 17 Post(s)
Hey folks,
I figured I'd follow up with this thread, for anyone who may search later. Sure enough, the push-n-brake test wasn't enough, with the forks out and on a bench, one of them has a leaking seal. They'll be torn down next week to check for bends and whatever else may be damaged.
Folks, don't get complacent about checking stuff after a dismount, stuff that seems or feels ok could really ruin your day later if a defect goes unnoticed.
Thanks for the feedback, guys, kick-ass as usual!
Burntclutches likes this.
- Leo Vince exhaust
BTF/PTM is offline
post #5 of 8 (permalink) Old 01-29-2016, 12:41 PM
Quoted: 326 Post(s)
if you bent your forks you almost certainly did in your triple clamps as well. apparently the rc51 triples are made of cheese.
have a close look at them while the bike is apart
post #6 of 8 (permalink) Old 01-31-2016, 12:28 PM Thread Starter
Quoted: 17 Post(s)
Thanks Wibbly! Any specifics on this idea? What I mean is, for example, is it a case of putting a straight edge over the surface to check for twists/warps, or maybe a twist in the vertical spindle that holds the steering bearings? I'll check both in any case.
- Leo Vince exhaust
BTF/PTM is offline
post #7 of 8 (permalink) Old 01-31-2016, 03:33 PM
One sign could be broken paint, if the metal is stressed enough it will crack the paint.
Best thing might be just to pull the triples out to measure flatness properly as well as the main steering shaft.
post #8 of 8 (permalink) Old 02-01-2016, 10:43 AM
Quoted: 326 Post(s)
pop them out and place them on a flat surface. bent ones won't sit flat.
another indication is to simply slide a pair of straight forks into them. if the forks have any trouble at all lining up, your triples are bent.
