Honest opinion wanted - Honda RC51 Forum : RC51 Motorcycle Forums
 2Likes
  • 1 Post By Wibbly
  • 1 Post By DuckyLilZilla
post #1 of 9 (permalink) Old 11-08-2017, 03:47 AM Thread Starter
DuckyLilZilla's Avatar
I?ve been reading a lot about how suspension is amongst the best upgrades to a bike. I have no doubt that a $2000 HO204 / fork rebuild / linear link is a solid upgrade to a bike but is it worth the $2000? I?ve also read that the RC51 had some of the best OEM suspension offered at the time but obviously it won?t be set up for each individual rider. My question is what is the difference between stock OEM suspension properly set up for the track and Öhlins properly set up? I?m 210 lbs without riding gear on.
2002 Baconator SP2 with things and shit
DuckyLilZilla is offline
post #2 of 9 (permalink) Old 11-08-2017, 07:22 AM
Dutchy's Avatar
Dis
Po
Sa
Ble
In
Co
Me
Set your suspension up ballpark right, or pay a guy trackside to do it for you. Go ride and enjoy the ride
"There is no way to happiness, happiness is the way..." Be happy with what you already got, and that by the way, is a lot. Strive for more, sure. But step back and look what you already have.
Then as you progress in your track day/riding days, you look at your wallet and evaluate what else you could do with the $2k disposable income your have.
It took me 35+ years to get to my SP. My first bike was a
and I loved it to bits... With hindsight, everything "sucked big time" compared to XYZ...
In isolation, no it is not worth 2k. but seen in the bigger picture of your hobby......
PS: my SP2 came with Ohlins already on it... I subsequently had K-Tech SSK put in up front. and no, I donot do track days...
YMMV
Dutchy is online now
post #3 of 9 (permalink) Old 11-08-2017, 10:53 AM
Quoted: 90 Post(s)
For the front end, better quality valves and shim stack, plus spring rates for ones weight goes a long way.
No need to spend $2000 on replacement cartridges if you don't need it.
For the rear, a better quality adjustable/rebuildable shock also with correct spring rate for rider weight will really help.
As an example: The suspension on my '08 Triumph Tiger 1050 was absolute garbage.
Highly under-sprung and under-damped for my weight (or pretty much anyone).
Felt more like those playground rides mounted on coil springs. Made one's ass pucker when anywhere close to pushing it.
I saved up and bought a Race Tech Gold Valve kit and springs for the front, and a Nitron R3+HYD shock for the rear.
Still fine tuning the front for my riding style, but the shock is spot on.
Night and day difference even as is, and that's no exaggeration. Now I ride with confidence (and having fun!) and bike is handling the way it was meant to.
post #4 of 9 (permalink) Old 11-08-2017, 12:31 PM
Quoted: 326 Post(s)
Yes of course it's worth it. Of all the things to do to the 51 suspension is probably in the top spot, if not it's in the top 2 or 3
Just because the bike isn't overly expensive doesn't mean that parts aren't worth installing.
The difference you get in enjoyment from having a well suspended motorcycle is worth 2000 bucks on nearly anything
Trace likes this.
post #5 of 9 (permalink) Old 11-08-2017, 08:07 PM
Quoted: 31 Post(s)
I'd go for a new shock and linear link in the rear first..if you have 2g to spend then a kit in the front...kill 2 birds with 2000 stones...lol...rear shock and link sucks balls.
rccbrz is offline
post #6 of 9 (permalink) Old 11-08-2017, 10:04 PM
Quoted: 68 Post(s)
dig through the search engine, you'll find stuff done cheaper, some of which you can do. It won't be Ohlins or Matrics or Wilbers or etc. but it will be better than what you have...
2005 Honda RC-51 SP-2 Project Bike (started)
2014 Ducati HyperProject (ongoing)
BadToTheBown is offline
post #7 of 9 (permalink) Old 11-08-2017, 11:21 PM
Trace's Avatar
Quoted: 47 Post(s)
I think you already know that money spent on suspension is the best BuckBang, or you wouldn't have asked the general question. But, in addition to the proper upgrading of the OEM suspension, you should also consider the AGE of that suspension. Even if it was "okay" from the factory (which it is not), it still would need a rebuild here in 2017, right? So think of it as breaking even.
I recently spent $800 for the total fork rebuild/respring/valving, and $850 for the lovely Ohlins shock, all provided by Kyle/LDH specifically for my 210 lb nekked weight. I also bought the link, because I'm never two-up on this bike. That's less than $2K, and the suspension is simply a totally different animal now. Compliant, confidence inspiring, almost cushy compared to old OEM workings.
Yes, Wibbly is right. Suspension is the best mod on our older bikes. Sure, a new Yammie R1 is all the tits and needs nothing, but our old pigs can use an upgrade to the 21st century.
2000 RC #001201
2014 Duc MultiStrada
2013 Corvette Grand Sport
Trace is offline
post #8 of 9 (permalink) Old 11-09-2017, 11:04 AM
Dutchy's Avatar
And oh yeah,
loose 20 pounds....
(U2 Trace.....)
post #9 of 9 (permalink) Old 11-10-2017, 05:26 AM Thread Starter
I think you already know that money spent on suspension is the best BuckBang, or you wouldn't have asked the general question. But, in addition to the proper upgrading of the OEM suspension, you should also consider the AGE of that suspension. Even if it was "okay" from the factory (which it is not), it still would need a rebuild here in 2017, right? So think of it as breaking even. >[IMG class=inlineimg]https://www.rc51forums.com//forums/images/smilies/smile.gif[/IMG]
You?ve about sold me with this post alone. Valid points. Will be a project down the road and not as immidiate as originally thought.
Trace likes this.
