Traxxion Maxton Action - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 3 (permalink) Old 03-18-2019, 10:04 AM Thread Starter
Question Traxxion Maxton Action
Hello from London,
The picture attached shows new Traxxion fork valving on the left and what I believe and recall is Maxton (a British suspension firm) valving on the right, which is currently fitted.
The obvious problem is that the Maxton attaches to the rod with a threaded male holder and the Traxxion with a female.
Two questions: is the standard Showa valve holder male or female? Parts fiches don't show this level of detail.
Second, any thoughts on what to do? Rebuild project on hold until I can figure this out. Looking forward to hearing from some good experts on the Forum.
Adam, London
Name:	RC51 Valving.jpg
smallmana is offline
post #2 of 3 (permalink) Old 03-18-2019, 01:07 PM
Quoted: 332 Post(s)
I've never understood why they don't just replace the valve & shim stack (as an assembly) onto the OEM holder like we do with the Ohlins piston kit. So simple... Works great with no special needles, adapters or rods etc.
post #3 of 3 (permalink) Old 03-19-2019, 10:30 AM Thread Starter
Well indeed. The answer, it turns out, is that Maxton amend the rod too. Hence why the Traxxion, which fits the standard Showa set-up, won't fit. Ohlins might have been cheaper at this rate...
