shock adjuster - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 4 (permalink) Old 01-27-2013, 12:18 PM Thread Starter
Polarbear's Avatar
Quoted: 6 Post(s)
shock adjuster
i was trying to adjust the switch on my rear shock yesterday and the switch will not turn! trying to switch it to a softer setting as they last owner had 3stone on me. put everything i had into it and my hand just slid round it. ive got a maxton shock. anyone else having this prob or know hoe to fix it?
Honda SP1.5 owner
Polarbear is offline
post #2 of 4 (permalink) Old 01-28-2013, 10:02 PM
Plwtwo's Avatar
I'm not familiar with a Maxton shock, could it have a lock on it? Maybe a pull collar or a reverse nut which needs to be loosened?
I'd suggest shooting Maxton a email.
[email protected]
Good Luck. Preston
03 RC-a few nicnacs.
Plwtwo is offline
post #3 of 4 (permalink) Old 01-28-2013, 10:39 PM
Quoted: 90 Post(s)
Are you referring to the spring preload adjuster or compression damping adjuster?
If the shock uses the stick type preload adjuster collar, often a set screw is used.
The set screw may need to be loosened to rotate the collar.
What model of Maxton shock are you using?
post #4 of 4 (permalink) Old 01-29-2013, 02:51 AM
Polarbear, Pic's would be of great help here, for us all to help you.
DuckHunterComposites
Duckhunter is offline
