power commander 3r error - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 9 (permalink) Old 03-28-2013, 03:32 AM Thread Starter
before you tell me to search, i did. i bought a used power commander 3r and am having an issue with "file and PC versions incompatibe". please help me figure this out.
Heres what i can tell you:
commander is correct part # for my 2000 rc51
the maps and software installed are correct versions accoding to their website.
i can load/edit/save file into pc software.
the pc led's light up and the surface buttons work.
with the bike running, the display at the top will show rpm, tp, etc.
i have a cheapo usb-serial cable off ebay, and my computer recognizes it under COM3, as does the power commander software.
the problem:
i cant upload or download maps to the power commander, and when i try to it gives me the "file and PC versions incompatibe" error that apparently is famous with these.
is my pc3r a bust? or do you guys think its a laptop issue? mac with windows installed btw.
THANKS!
torque monster is offline
post #2 of 9 (permalink) Old 03-28-2013, 09:53 AM
i dont have an answer except calling power commander tech support. i was having an issue that was crushing my skull. i called them and it turned out i was just being a retard.
f3racer is offline
post #3 of 9 (permalink) Old 03-28-2013, 02:01 PM Thread Starter
f3racer thanks for the nudge to call em. i usually get so pissed about these things and expect the customer support to not help me that i turn to forums first. anyway i did call them and they figured it out really quick.
for those who will stumble upon this in the future, heres the problem, even though they have .map files on their site that the software recognizes, they are formatted differently and have two extra tables for TP and something else which the pc3r does not recognize.
I got an email with a map that is correct for this ancient power commander, and just have to edit that map, copy paste data from other newer maps etc. the map that works is M105-302.map buts its not the same as on their site. email me at [email protected] and ill forward it to you.
post #4 of 9 (permalink) Old 03-28-2013, 02:42 PM
I had the same issue. I recently installed my factory exhaust back on, and couldn't get the right map to load. I had to call DynoJet also, the first guy sent me a link to their page with the maps. I already had tried that. Useless. I called back and a different tech helped me, this time, he emailed me the specific map I needed (factory exhaust) and once I got the COM port issue resolved, it loaded properly.
I think my problem was when I downloaded the map from their page - to my computer - something got messed up. I believe that's why the specific map he emailed to me downloaded properly. He went on to mention there are occasionally glitches when downloading the older 3r maps, and he said to use the best usb/serial cable I could find. I paid $40 at Radio Shack for a gold plated one.
post #5 of 9 (permalink) Old 03-28-2013, 03:32 PM
Glad it worked out!
f3racer is offline
post #6 of 9 (permalink) Old 03-29-2013, 11:59 AM Thread Starter
Just on a side note, even with ignition tuning the pc hardly ads any power, however it did take the crzy ppeakiness out of the 2-5k range so rolling on the throttle in turns feels safer. Im hoping my mpg goes up cause looking at the map, its leaned out in a lot of areas.
post #7 of 9 (permalink) Old 03-29-2013, 01:25 PM
I'm sure that could be helpful for some. What exhaust are you running?
Full system or slip-ons? High mount?
post #8 of 9 (permalink) Old 03-29-2013, 10:08 PM Thread Starter
i have "moriwaki titanium zero" slip on mufflers painted black. the exhaust manifold coming from the heads is original. im not sure but i think theyre high mounted, higher than stock anyway and there are no passenger foot pegs as a result.
the map that i was sent is not for this setup, it is merely a foundation that works. however you can download 105-011 which is for moriwakis and copy/paste the fuel table. timing is unchanged.
post #9 of 9 (permalink) Old 03-30-2013, 12:52 AM
LDH has a few custom maps up on his mods page. He has one for a sato lowmount SP1 that I'm going to try soon.
