Help with my headlights - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 7 (permalink) Old 04-01-2013, 10:40 PM Thread Starter
knucklz's Avatar
I have a 2000 RC and it was running fine other than an occasional hard start and resetting of trip meter and at times if I killed it while taking of I could sometimes pull the clutch and it would start other times I would have to put in neutral to start. I recently installed a USB power commander in it and then the headlights quit working. A friend checked things out with a voltmeter and didn't find a short so I put new bulbs in. A couple of days later the low beam is blown again we have stripped it down and started tracing and checking wires and switches if we check for a short at the low beam the meter sounds an alarm we can wiggle the push button start and it will quit. Not sure if that is the problem or not and don't want to buy a new start button if that is not the problem as I will not be able to return it. I have been told that it is a problem with my charging system not sure what to do here. I am trying to get it fixed before I move to Texas in a couple weeks!!!! Thanks
knucklz is offline
post #2 of 7 (permalink) Old 04-01-2013, 10:56 PM
I'm thinking charging system as well...
post #3 of 7 (permalink) Old 04-01-2013, 10:57 PM
Have you checked what voltages are being put across the battery as different revs? It should stay below 15V. If it's going above, your voltage regulator may be gone - which could explain why your bulbs are blowing. If there is no a problem with voltage regulator, it may be that you touched the glass when fitting the halogen bulbs. The grease on your fingers can shorten the life of them too.
post #4 of 7 (permalink) Old 04-01-2013, 11:17 PM Thread Starter
knucklz's Avatar
We have ohmed just about everything out except charging system will do that tomorrow. The low beam plug is showing a short when the bike is off and when it is running it shows continuity across the positive and ground on the plug why is that?
knucklz is offline
post #5 of 7 (permalink) Old 04-01-2013, 11:39 PM
Because ohms measure resistance, so when off there is no continuity, but when on the low light is always running and there is continuity.
post #6 of 7 (permalink) Old 04-02-2013, 12:19 PM Thread Starter
knucklz's Avatar
Ok charging system is fine reads 14 volts so whats next you can call me number is 6057899840 thanks
knucklz is offline
post #7 of 7 (permalink) Old 04-02-2013, 06:17 PM
If your low beam bulb is burning out you have some issues beyond charging. I'm no expert here on electrical and hopefully others can help more. Could be wiring, ground issues, or battery problems. Hidden intermittent wiring shorts. Could also be an intermittent battery short (need new battery).
I'd have the battery load tested a couple of times and see how it performs. Then move onto other testing. Also use the service manual trouble shooting.
