Clutch pull issue - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 13 (permalink) Old 04-17-2013, 12:01 PM Thread Starter
Clutch pull issue
So I did some searching--seems most people have the clutch engaging at the END of the lever as its 90% out. Well, mine is opposite. Fluid is fine. What else could it be? Still a bubble in there? Problem is....im at work 60 miles from home with the bike... I have a hair trigger that disengages the clutch like 2mm after I start releasing the lever.
waldo877 is offline
post #2 of 13 (permalink) Old 04-17-2013, 01:09 PM
Sounds like you may have air in the system.
Just like many others, my clutch engages towards the end of its travel.
Often, the air collects at the upper end of the fitting where the banjo bolt meets the master cylinder.
We have had at least two members here who (after repeated unsuccessful attempts to bleed air out of the line) have slightly loosened the banjo bolt while squeezing the lever and had air escape (of course, quickly tightening the bolt after bleeding), then reporting a nice firm action with correct operation.
post #3 of 13 (permalink) Old 04-17-2013, 01:31 PM Thread Starter
Thanks, i'll give all that a shot. I don't see any fluid leaking--so I suspect a bubble rather than a bad seal. Hopefully it'll make it home...its engaging closer and closer to the end of the travel.
waldo877 is offline
post #4 of 13 (permalink) Old 04-17-2013, 03:24 PM
That's the way I always do mine now, as I found it far easier to bleed using this method.
SP1 Jock is offline
post #5 of 13 (permalink) Old 04-18-2013, 11:41 AM
When did you last flush the fluid? I know you said the fluid was fine, but if you've never had the slave cylinder off to inspect, you could have a problem with crud in there. Flushing doesn't always get that stuff out cause it settles to the bottom and the bleeder valve is at the top.
If the banjo bleed doesn't do the trick, consider taking the master & slave cylinder apart for inspection.
What you describe happened to me, to the point the clutch wouldn't disengage at all. The sludge you see in the slave cylinder was also in the master cylinder and piston and gumming it up too.
ID:	13585   Click image for larger version
post #6 of 13 (permalink) Old 04-18-2013, 08:11 PM
macDANalay's Avatar
This was my problem too. Immediately fixed it after I bled the air from the banjo bolt.
Don't listen to this guy. He's whacko
'08 HD Dyna FatBob
'03/13 BOTM - thx every1!
macDANalay is offline
post #7 of 13 (permalink) Old 04-18-2013, 11:28 PM
Says the guy who works all night and stays up all day.
post #8 of 13 (permalink) Old 04-19-2013, 11:27 AM Thread Starter
Thanks for all your help guys. Turns out it was the slave. THe fluid looked fine, in the fact that I thought the reservoir was full. It looked like it..but wasn't. I didn't want to touch ANYTHING until I made it home.
When I got home, the reservoir was empty. Fluid definitely dirty. It leaked around the slave gasket. I ordered a new slave (used) and gasket. That will need to be replaced. One question--Does that pushrod just fall out? I know theres usually a ball behind it. Im worried that will dislodge and cause problems. Can I just pull the slave off?
waldo877 is offline
post #9 of 13 (permalink) Old 04-19-2013, 12:28 PM
My opinion, you should just pull your slave cylinder off and order new cups and gasket. They're very cheap.
I wouldn't just slap another used one on, it needs to be inspected for the condition of the rubber bits. Same as your existing one. So why buy another used one?
http://partsfinder.onlinemicrofiche....p?make=hondamc
part # 6, 9 was all I needed for the slave.
Since you're into it this far, I would look at the master too.
part #3.
Use DOT4 brake fluid.
That rod; don't pull it all the way out. It slid out about an inch or two on me, I just pushed it back in.
post #10 of 13 (permalink) Old 04-19-2013, 12:55 PM Thread Starter
Great. Well, the used one I bought looks mint, and it was only 20 on ebay--I figured what the hell..
I'll check the master too I suppose.
waldo877 is offline
