My bike will not start . I have changed the starter , battery , solenoid and fuses . - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 17 (permalink) Old 04-18-2013, 07:13 AM Thread Starter
Toat is offline
post #2 of 17 (permalink) Old 04-18-2013, 11:02 AM
Does the pump prime?
How much voltage is the regulator putting to the battery?
What does the bike do when you try to start it?
Any codes?
post #3 of 17 (permalink) Old 04-18-2013, 12:19 PM Thread Starter
It makes a click that comes from the solenoid when I try to start it .I at first thought that was it but after changing it I have the same issue . Yes the pump primes as well .
Toat is offline
post #4 of 17 (permalink) Old 04-18-2013, 12:25 PM Thread Starter
Also there are no codes .
Toat is offline
post #5 of 17 (permalink) Old 04-18-2013, 12:29 PM
Quoted: 90 Post(s)
You said you changed the battery.
Is the battery currently fully charged with over 12v (preferably 13v) shown on a voltmeter?
Anything below 12v is considered low, and 11v is considered effectively dead.
post #6 of 17 (permalink) Old 04-18-2013, 12:32 PM
Quoted: 90 Post(s)
Here's the starter circuit diagram for reference.
post #7 of 17 (permalink) Old 04-18-2013, 12:56 PM Thread Starter
I actually bought a new battery yesterday just to be sure . Voltmeter read 12.7 . I will retrace my steps and recharge just to be sure . Thanks .
Toat is offline
post #8 of 17 (permalink) Old 04-18-2013, 04:05 PM
So you hear your starter solenoid clicking?
If you're sure it's the starter solenoid clicking, then some power is getting to it, but not enough to get the starter to spin. Bad ground/faulty wiring?
There's a starter relay on the left side of your subframe. You have to remove the tail section to access it - I'd inspect that relay and fuse and see what noises it makes _ if any _ when you try to start the bike.
This sounds dumb, but you're sure the kill switch is in proper position?
post #9 of 17 (permalink) Old 04-18-2013, 04:17 PM Thread Starter
I have the fairing off . It may be a grounding because after a couple of tries , my new battery is low as well . Haha . Yeah . I did check the kill switch . Thanks and I will keep you posted on progress . Will get back at it tomorrow .
Toat is offline
post #10 of 17 (permalink) Old 04-20-2013, 01:11 AM
Bank angle sensor input to CPU?
You can try and start it with a 12v Powerpac clamped onto you battery terminals.
Did you blow any fuses before you replaced them? If it was the 30 amp main you may have a short.
rc51 Red Rider is offline
