F1 light /check engine light questions - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 12 (permalink) Old 05-22-2013, 12:35 PM Thread Starter
JonPowerShift's Avatar
Just picked up a 02 rc51, pretty much stock except for the yoshi slipons, DID chain , crg levers,vortex clip ons,I was wondering what the F1 light means when it's on ,(mine isn't) and also how do u check it , is it like a jack that u plug into and scan (similar to obd2 cars) and gives u a code , thanks guys if u have pictures or links that would b helpful or any info?
JonPowerShift is offline
post #2 of 12 (permalink) Old 05-22-2013, 12:38 PM
Search is your friend. I got 301 results in 0.31 seconds. You can have your answer in less time than it took to post the thread.
Nice bike. Hope you like it.
post #3 of 12 (permalink) Old 05-22-2013, 01:02 PM
The light will blink a certain number of times when something is wrong. The service manual will tell you what the codes mean. It is just like the blinky check engine light in your car.
I'm always right.
2011 Bike of the Year
post #4 of 12 (permalink) Old 05-22-2013, 02:14 PM Thread Starter
@b miller , thanks again so it's like obd1 cars where u have to read long/shirt flashes that tell u a code , is there a service jack/plug where I have to plug into or the light jus flash by itself
post #5 of 12 (permalink) Old 05-22-2013, 03:22 PM
There's a 2P white service connector that hangs there with nothing plugged into it. You just jump a wire accross both terminals to get FI reading from the light.
If you have no problems now with the bike, best to clear out the old stored codes so when something new happens, you wont just add it to the old codes and be surprised that you have 6 different codes all flashing at you, when there's only one new problem.
post #6 of 12 (permalink) Old 05-22-2013, 04:31 PM Thread Starter
Thanks jondog , mad props to u , looks like the connector is next to the battery under the seat , I'm gone check it taday an see what I get , (hopefully) none .
post #7 of 12 (permalink) Old 05-22-2013, 08:26 PM
Quoted: 90 Post(s)
On SP2's ('02 to '06), it's a green 2P connector located near the battery box.
You'll need to remove the rider's seat to access it.
Jumper the connector, switch the ignition on and read the codes.
post #8 of 12 (permalink) Old 05-22-2013, 09:29 PM Thread Starter
@subsailor ,,XLNT!! Thanks man . I'm gonna make sure everything is Kools , also ? If I was to get a pc3 , would it still give me codes , or would I loose tht function ..
post #9 of 12 (permalink) Old 05-22-2013, 11:00 PM
Interesting point SubSailor.
Then that's another difference between the SP1 and SP2. SP1 having a white service connector.
post #10 of 12 (permalink) Old 05-23-2013, 02:12 PM
Quoted: 90 Post(s)
You'll still get ECU codes.
