pc3 usb help - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 13 (permalink) Old 06-15-2013, 10:46 PM Thread Starter
pc3 usb help
I just installed a brand new pc3 usb...downloaded the maps off of the Rogue site. Map was converted to file that USB PC can read and use.
I go to send map and get an "error" message saying can't send map?
I searched and tried calling Dynojet but they are now closed until Monday.
I can wait but just wondering if anyone has any hints or suggestions.
Uninstalled software and reinstalled, tried installing maps directly off of Dynojet website but still get the same message.
Thanks in advance
post #2 of 13 (permalink) Old 06-15-2013, 10:50 PM
Andrew's Avatar
Is the PC on when you are trying to send the map? Your key and kill switch needs to be in the on position to turn the PC on and send a map unless using 9v battery.
Andrew is offline
post #3 of 13 (permalink) Old 06-15-2013, 10:56 PM Thread Starter
Im using the 9v option...yes a brand new 9v battery. Any other suggestions?
post #4 of 13 (permalink) Old 06-15-2013, 10:59 PM
Andrew's Avatar
Are you grounded to the neg battery terminal? I would also avoid 9v option and try sending map with bike running
Andrew is offline
post #5 of 13 (permalink) Old 06-15-2013, 11:07 PM Thread Starter
I guess I should rephrase I do not have a laptop, so I mounted the pc and realised that the computer is no where near the bike. So I took the pc out again and attached the 9v option.
I thought that the pc could be removed and plugged into the pc via the USB cable, a map loaded and then take the pc, mount it and you're good to go? Am I wrong in thinking this?
post #6 of 13 (permalink) Old 06-16-2013, 12:36 AM
No, you are correct. That is the point of the 9v option. He was just suggesting another method to try. Have you tried installing different maps?
2003 SP2
Used to have Kwaks, but they're gone
RememberTheMallamo is offline
post #7 of 13 (permalink) Old 06-16-2013, 12:59 AM Thread Starter
Yes maps right off of the site...no love.
post #8 of 13 (permalink) Old 06-16-2013, 01:59 AM
Andrew's Avatar
Is the PC lighting up when you plug the 9v into the PC? Sounds like you got a bad unit
Andrew is offline
post #9 of 13 (permalink) Old 06-16-2013, 02:10 AM Thread Starter
Ya pc lights up...that's why I'm sorta stumped?
post #10 of 13 (permalink) Old 06-16-2013, 04:39 AM Thread Starter
Well after more searching I came across a thread about some sort of detent on the USB cable on the PC side...so I recheck the amount of pressure needed to positively seat the USB cable and voila it snapped in about an extra .5 millimeter.
In my defence I've used PC's before and I don't ever remember having to push that hard to seat the cable. Also being an electronic device I was being rather gentle when handling it but I guess it's not a bluray player.
Map installed and good to go...thanks guys.
