header stud install - Honda RC51 Forum : RC51 Motorcycle Forums
post #1 of 21 (permalink) Old 06-16-2013, 12:02 PM Thread Starter
screamin chief's Avatar
header stud install
hey all. I was replacing my exhaust gaskets and when I was unscrewing the bolts the whole stud came with it and I noticed it was a little bent. so I ordered new and was curious if there was a specific way to reinstall the stud. thanks
2000 RC51
1985 ATC 350X
2009 Silverado SS clone
Lots and lots of guns!lol
screamin chief is offline
post #2 of 21 (permalink) Old 06-16-2013, 12:06 PM Thread Starter
2000 RC51
1985 ATC 350X
post #3 of 21 (permalink) Old 06-16-2013, 12:58 PM
The easiest is to double nut the stud. There are two schools of thought on whether to loctite the stud or use some sort of never-cease. Me I usually just use a little never-cease and be done with it.
post #4 of 21 (permalink) Old 06-16-2013, 01:00 PM Thread Starter
What do you think it should be torqued to?
2000 RC51
1985 ATC 350X
post #5 of 21 (permalink) Old 06-16-2013, 01:02 PM
Talking
Not in the manual? Is it 8x1.25? If so no more than 24lb/ft.
post #6 of 21 (permalink) Old 06-16-2013, 01:05 PM Thread Starter
thank you sir
2000 RC51
1985 ATC 350X
post #7 of 21 (permalink) Old 06-16-2013, 02:14 PM
Doesn't that depend on the alloy of the stud? I'm thinking that it's a harder alloy than most, due to it's environment. I don't know. Wouldn't that require a little more lbf.ft's?
post #8 of 21 (permalink) Old 06-16-2013, 02:17 PM
I was thinking more about the aluminum that the stud is going into...
post #9 of 21 (permalink) Old 06-16-2013, 02:56 PM
It's probably 10B22 or a like alloy...I'd use anti seize too.
Sent from Motorcycle.com App
post #10 of 21 (permalink) Old 07-30-2013, 03:43 AM
euro_e30's Avatar
as a european car specialist (and otherwise jack-of-all-trades) ive seen/pulled/broke/removed many a stud in aluminum. using a install/remover socket ($30-40 bucks on the tool truck) and thread chasers is the way to go. anti-seize if you want it to come out again (a little goes along way)(also with the possibility to back out when you dont). double-nutting when the socket wont fit (trying not to use the nuts youre gonna use for the part. threaded studs with clean threads should be lightly oiled (the correct loc-tite formula for the application),spun in finger tight and barely snugged, the nuts are what get torqued to spec. when you go past that with the studs, youre pre-loading the threads which causes them to weaken when you torque the nuts. when you do have to remove them, the threads come out with the stud. (use time-serts, not heli-coils for repair)
just my$0.02....
My Toys:
'03 RC51
'08 Nightster
'89 BMW 325iS
'85 Toyota SR5 Pick-up
'85 Toyota 4Runner
RM125 engined shifter kart
euro_e30 is offline
